Generac Generators (SEARS, etc.) Restoring, maintaining and operating Generac generators.
Manual for MC-40, Model 6897-3 found
this thread has 6 replies and has been viewed 3243 times
Old 07-17-2011, 10:05:40 PM
drmax drmax is offline
Default Generac MC 40, Mod 6897-3 NO POWER
I have an old Generac generator, MC 40, Model # 6897-3, that I got for free. From a motorhome. How do I wire the output? I dont get any power with my multi meter with the 3 output wires? Does anyone have a manual for this generator? I'm trying to get it running for my brother who is on SSI. Any help would be helpfull. I will try to answer as fast as I can to all replies.
Old 07-18-2011, 01:44:52 PM
Default Re: Generac MC 40, Mod 6897-3 NO POWER
There are 4 wires that were cut off when the generator was removed.
Could this be a remote start wireing loom? Would the generator still put out power if these 4 wires are taped off? Engine runs and starts from the external panel. I even checked for power at the rear of the breaker in case it was broken. No 110V.
4 Wires are numbered 10,14, 17, and 20. ( these are the numbers on each of the grey wires, embosed on the grey outer covering )
HELP
No luck finding an owners manual or wireing schematic.
Generator was supposed to work and make power.
Any ideas?
Dr Max
Old 07-18-2011, 02:59:35 PM
Fred M. Fred M. is offline
Dr. Max-
I found a manual 051834.pdf on the web, that should help. It is about 25 Megabytes, so would take a while to download.
http://www.generator-parts.com/manua...-rv/051834.pdf
Fred
The Following User Says Thank You to Fred M. For This Post:
Old 07-18-2011, 03:16:48 PM
BTPost's Avatar
BTPost BTPost is offline
Images: 1
Talking Re: Generac MC 40, Mod 6897-3 NO POWER
Ok Dr Max, according to Fred M's PDF, your Chopped off wires are for a Remote Start/Stop Panel. Looks like if you are still having AC Power issues, it is in the AVR System. Check the Exciter Voltage when running.
Bruce in alaska
The Following User Says Thank You to BTPost For This Post:
Old 07-18-2011, 06:49:47 PM
Douglas123 Douglas123 is offline
Smile Re: Generac MC 40, Mod 6897-3 NO POWER
Hi BT, I will check that pdf in a minute. I believe this old unit had a little sealed plug in rectifier. Probably obsolete now but can be repaired.
The manual Fred found appears to be the correct manual and will be most helpful in troubleshooting your problem. Excellent bathroom reading material. Kudos to who or whomever originally took the time to put this original manual into a pdf file.
The Following User Says Thank You to Douglas123 For This Post:
Old 07-18-2011, 09:12:15 PM
You people are the GREATEST. Downloading the manual as I type. Would be great if I could get it working for my brother. More as I read up on the generator, and do some tests.
THANKS
Dr Max
Old 07-19-2011, 12:14:10 PM
Smile Manual for MC-40, Model 6897-3 found
Thanks to Fred M, I have the manual for my generator. Where he found it I don't know, but BIG thanks.
Thought I would share the link with everyone so others can download it.
Thanks again
Dr Max
Last edited by BTPost; 07-19-2011 at 12:34:31 PM. Reason: Please try to keep to a single thread for any one unit....
Dometic DCM-45 Manual finally found Don Smith Generac Generators (SEARS, etc.) 17 06-07-2015 08:58:17 AM
Found AENL Manual Elden DuRand Wisconsin Engines 1 08-06-2010 11:08:25 AM
IHC TD 14A model found Paul Spence Antique Gas Engine Discussion 5 11-22-2009 11:18:59 AM
Found Owners Manual For Onan MDJE in PDF Shawn New Onan Generators 1 07-13-2009 10:36:11 AM
