Stromberg UC-3/4 Parts, Parts Diagram?
this thread has 1 replies and has been viewed 2092 times
Old 08-01-2011, 07:23:27 PM
KD5BYB's Avatar
KD5BYB KD5BYB is offline
Images: 3
Arrow Stromberg UC-3/4 Parts, Parts Diagram?
Evening all,
I'm rebuilding a Stromberg UC-3/4 from my Wisconsin AEH. It is an L45B2, Stromberg part number 426020A.
The Idle Tube is blocked solid - no matter what I try it won't pass any air nor fluid (was using alcohol and compressed air to test not gasoline). If I understand how this carb works correctly, no fuel from the idle tube = no fuel at idle.
The only way to get in there to clean it is to remove the Idle Tube and the Main Discharge Jet.
Here's the rub - I am rarely successful in removing similar parts off of Briggs carburetors. Thankfully, Briggs parts are pretty easy to find.
So, before I take the thing apart, and possibly damage these pieces, I want to make sure I can get new ones.
Here's the other rub - the only parts list I can find is in a Wisconsin Carburetor manual, and while it lists the parts, it does NOT list part numbers for the UC carb.
So! Anyone have a good parts number listing for a UC carburetor and/or know of a good source that would have an Idle Tube and a Main Discharge Jet for the same?
thanks much,
ben
Old 08-03-2011, 08:07:27 AM
KD5BYB's Avatar
Images: 3
Default Re: Stromberg UC-3/4 Parts, Parts Diagram?
Morning all,
An update - I sent an e-mail over to site sponsor McDonald Carb and Ignition. In less than two hours, I got a reply back from them indicating that they could supply both the main jet and the idle tube.
I was extremely happy!
thanks much,
ben
The Following User Says Thank You to KD5BYB For This Post:
Briggs model 8 parts diagram mytwins1999 Small Air Cooled Gasoline Engines 14 01-02-2015 02:53:41 AM
Stromberg UR-3/4 Carburetor schematic & parts list James Wallace Small Air Cooled Gasoline Engines 5 02-27-2014 12:02:51 PM
Murray Parts Diagram wheelhorseman Garden Tractors / Mowers / Scooters 3 05-01-2010 10:12:08 AM
Fairbanks parts diagram and listing R. Kern Antique Gas Engine Discussion 0 07-20-2008 10:23:12 PM
FM Z Parts Diagram 4 all Kevin Pampuch Antique Gas Engine Discussion 10 06-03-2008 08:25:57 PM
