mep002a/mep003a float switch connector
this thread has 7 replies and has been viewed 1425 times
Old 08-02-2011, 05:28:17 PM
scottatbhm scottatbhm is offline
Default mep002a/mep003a float switch connector
The straight connector connected to my MEP002a float switch has been sheared off. P/n ITT Cannon MS3108R10SL-3S. It has an elbow connector connected to the top of it. I just need the straight connector. I'd like to buy one if someone has one for sale. But I thought I might wrap the threads in teflon tape and try a JB weld repair. The problem is I can't tell by looking at it, how it should be aligned. Can anyone tell me if the keyed slot on the bottom aligns with the keyed slot on the top? Thanks
Old 08-04-2011, 10:11:30 AM
Default Re: mep002a/mep003a float switch connector
Sometimes a picture is worth a thousand words. This is the sheared connector.
Old 08-04-2011, 10:15:46 AM
There are three different ways I can align it and then JB weld it together. I think the correct alignment is as depicted below. Can anyone confirm this for me? Thanks
Try again, image didn't upload
Old 08-04-2011, 10:17:54 AM
I can't seem to upload second image.
Old 08-04-2011, 12:31:38 PM
BTPost's Avatar
BTPost BTPost is offline
Images: 1
Talking Re: mep002a/mep003a float switch connector
Why do you not just BUY a new connector from ITT Cannon? These are available from just about ANY of their distributers.
Bruce in alaska
The Following User Says Thank You to BTPost For This Post:
Old 08-04-2011, 12:58:38 PM
I was hoping to repair it for less than the $60 they want for it.
Old 08-04-2011, 05:59:40 PM
Jim Kinler Jim Kinler is offline
try delks iam sure you can get it used reasonable. if you have the 0perator tm the wiring diagram will give you the info. you need.
The Following User Says Thank You to Jim Kinler For This Post:
Old 08-05-2011, 02:35:41 PM
Richard L Richard L is offline
Send me an e mail and I will send you the contact info for a person in Texas who will fix you up and treat you right.
The switches in those float senders are verf fragile and work with a magnatized float that open the contacts,would go for a replacement unit. Also the contacts for the switch are rated at 1 amp,and will only run a relay.
looking down at the connector, the two terminals to the right of the key are the active one,.
R
The Following User Says Thank You to Richard L For This Post:
MEP002A -- remote start? hahnkl Military MEP and Aircraft Gen-Sets 6 10-12-2011 09:14:44 PM
MEP002A/MEP003A not battery charging Onan Military MEP and Aircraft Gen-Sets 2 06-16-2011 09:53:42 PM
MEP002A whats the difference? maximusbigdog Military MEP and Aircraft Gen-Sets 4 01-07-2009 11:43:20 AM
PE-95k connector and carb Jim Kinler Military MEP and Aircraft Gen-Sets 7 11-29-2008 10:57:03 PM
Onan MEP002A purple Onan Generators 14 10-22-2004 05:10:35 AM
