JD Model E Ice Cream Maker & Exhaust
this thread has 5 replies and has been viewed 1389 times
Old 08-04-2011, 11:13:53 PM
MasseyMan1089 MasseyMan1089 is offline
Default JD Model E Ice Cream Maker & Exhaust
I recently purchased a John Deere E and have been contemplating what to do with it. It looks and runs great and I would like to put it to work. I have been reading countless articles on here about ice cream mixer setups and I cannot seem to find an answer to my question. Theoretically, most everyone's pulley sizes to the mixer should be close to the same size - since the engines run at or near the same speeds. Where do you get the pulleys at? I assume the shaft is just that, like 1" or 3/4" shaft, with bearings and set screws holding the pulleys on. I just can't seem to find much specific info about the size pulleys and where I can buy them. Also, nothing to do with the ice cream mixer, but how / where does a guy get the vertical chrome exhaust stack? Hopefully someone can solve all of my questions!
Old 08-04-2011, 11:33:45 PM
6hpMarty 6hpMarty is offline
Default Re: JD Model E Ice Cream Maker & Exhaust
The pullies bolt to the flywheel(either one), hit n miss will have pullies or watch ebay, or let me know I think I have an extra or two. Now if you are talking about modern V pullies then you will need an adapter, I see them from time to time on ebay also, hope this helps you !
Old 08-05-2011, 12:02:49 AM
Wayne A Thackery's Avatar
Wayne A Thackery Wayne A Thackery is offline
Massey,
Check out this site. Lots of good info on pulley size and RPM's to run the ice cream maker.
http://www.country-freezer.com/
Wayne A Thackery
Keizer, Oregon 97303
Old 08-05-2011, 07:06:42 AM
Tom Martin Tom Martin is offline
When I built my ice cream maker, I found a flat belt pulley on e-bay that I drive from the existing pulley on the engine, and bought the necessary v belt pulleys from Grainger. If I were doing it today, I would first try to find the v belt pulleys at Surplus Center, or from McMaster-Carr. I am using a Stover CT2 engine that has about a 4" pulley on it, and the flat belt pulley I found on e-bay is a 12". The others are sized to give me about 50 RPM at the freezer with an engine speed of 300 RPM.
Old 08-05-2011, 07:08:54 AM
Roger Peterson Roger Peterson is offline
I may have some polished stainless that could be used for exhaust, PM if you want me to take a looksie...
Old 08-05-2011, 04:06:28 PM
I read on some previous posts about the belt slipping when the ice cream is done, to avoid shearing off things. I think running a flat belt off the original flywheel (on the bolted on bell part) would be best and I guess Ill have to keep an eye out on Ebay for another flat pulley to put on the new shaft. Then on the other end, I will figure out what size V-belt pulley I need to slow it down to attach to the ice cream mixer.
Maytag Ice Cream Maker Tom Sampson YouTube Old Iron Videos 6 11-04-2015 05:06:47 AM
Ice Cream Maker tinmanlocal2 Antique Gas Engine Discussion 3 07-04-2010 09:12:58 PM
Ice Cream maker Tom Sampson YouTube Old Iron Videos 1 05-26-2009 07:32:50 AM
Ice cream maker mark II KeithW Small Air Cooled Gasoline Engines 8 12-11-2008 11:41:43 AM
OT ice cream maker DanR Antique Gas Engine Discussion 4 03-10-2006 08:28:12 AM
