Welding Shop
Welding Boiler plate
Welding 516-70 boiler plate does it need to be stress reliefed after welding.
this thread has 3 replies and has been viewed 2460 times
Old 08-17-2011, 08:33 PM
Steamisthestuff Steamisthestuff is offline
Default Welding Boiler plate
Old 08-17-2011, 11:44 PM
Default Re: Welding Boiler plate
Depends on two things-#1) How thick it is, & #2) Who you ask....
If you're talking about like 3/8" or so, not a problem. 3/4"....well, yeah.....
Mike
Old 08-17-2011, 11:58 PM
LundMachineWorks LundMachineWorks is offline
Mike
Actually, 3/4 and under does not need post weld heat treatment per ASME Section I. Other codes may be different. Up to 1" is exempt in the same code if you pre-heat to a minimum of 200 deg F. If it is over 1-1/2 it is automatically required. In order to really assertain whether you do not have to PWHT you need to read the appropriate code section, because there are some "if, thans, and thou's" which may make it applicaple.
A commonly missed part is Post Weld Heat Treatment is an Essential Variable in ASME Section IX. Meaning if your weld procedure is qualified with PWHT and you do not use PWHT for the production weld it is NOT a qualified (certified) weld. The situation is reversable also.
Jeff Lund
Lund Machine Works
ASME S Stamp
National Board R Stamp
www.lundmachine.com
The Following User Says Thank You to LundMachineWorks:
Old 06-29-2012, 04:56 PM
Joefromnc Joefromnc is offline
Stress releive with a air powered needle gun on every pass.
Correct serial plate on boiler? Casemaker Stationary Steam & Traction Engines 3 02-05-2011 01:57 PM
Thoughts on crankshaft welding/ engine block welding Mac Leod Small Air Cooled Gasoline Engines 10 04-14-2008 10:46 PM
what is the contact info for Oliver boiler and Stutzman boiler? MarkP Stationary Steam & Traction Engines 4 10-03-2006 07:44 AM
Welding Matt Fretwell Welding Shop 23 10-12-2003 07:35 AM
Hodge Boiler Plate Toby Neverett Antique Engine Archives 0 05-02-2001 03:13 PM
