Generac Generators (SEARS, etc.) Restoring, maintaining and operating Generac generators.
Generac GP7000E wont stay running
this thread has 3 replies and has been viewed 2842 times
Old 09-19-2011, 05:29:12 PM
Arthur j mello Arthur j mello is offline
Default Generac GP7000E wont stay running
its only a year old with ten hours .starts but dies after 10 or 15 minutes for some reason .seems like no fuel but cranks right up again and does the same thing .any Ideas would be appreciated.Im not sure if its related but battery does not seem to charge .I really dont mind pull start ,but its got to stay running thanks art
Old 09-19-2011, 06:26:02 PM
Question Re: generac gp7000e wont stay running
1) Check gas cap for proper venting. 2) Check all rubber fuel lines for condition, including internal collapse. 3) Check the fuel bowl and carb fuel inlet for debris and or restrictions. 4) If this unit has a fuel filter, replace it. If it has a fuel bowl assembly, check the internal screen for clogging. 5) Check operation of fuel valve - is it partially closed?
Other things to check - Does it have a low oil cutoff? Check the oil level! My FD has a 5,000 watt Honda that was only about a pint low on oil. It did the same thing, cut off after about 10 minutes. Topped off the oil, no more stalls! Put an inductive timing light on the coil wire. Does it show steady spark, when the engine quits, or does spark go away?
Old 09-21-2011, 10:25:29 AM
Arkie Arkie is offline
Default Re: generac gp7000e wont stay running
I suspect this generac gen should have a additional 4 digit or so model number so as to ID the proper engine type?
I would think about checking the oil and if ok look into bypassing the low oil sensor.
The timing light procedure the guy mentioned will let you know if the engine is starving for fuel or if it's losing ignition.
If it;s ignition bypass the low oil sensore, if its gas related, there is usually a very fine screen filter on the petcock that is on the bottom of the fuel tank.
You can blow air backwards through the fuel line with the gas cap removed so as to temporarily remove the restriction and clean the screened filters.
If the screens are clogged remove the fuel tank and clean all, if rusty replace tank.
The Following User Says Thank You to Arkie For This Post:
Old 09-21-2011, 06:01:52 PM
smallen smallen is offline
Default Re: Generac GP7000E wont stay running
check the things the others have posted, yours does have oil pressure switch located next to oil filter, may be the problem
this unit has 1 year warranty for commercial use and 2 year for residential use
---------- Post added at 06:01 PM ---------- Previous post was at 05:57 PM ----------
post the model as arkie posted it helps (005626-0)
The Following User Says Thank You to smallen For This Post:
Onan 6.5 NHEFA wont stay running dr fusion Onan Generators 7 07-18-2013 08:37:25 PM
Onan JB 7.5 wont stay running MBB Onan Generators 11 05-02-2011 01:45:17 PM
Onan 5 CCK wont stay running gpkull Onan Generators 12 02-09-2011 12:24:35 AM
5.0CCK wont stay running Hiites Onan Generators 18 10-19-2009 11:12:12 AM
12.5JC wont stay running 10fords Onan Generators 17 11-02-2007 09:19:00 AM
