Wagner Induction Repulsion Motor
this thread has 2 replies and has been viewed 2099 times
Old 09-21-2011, 10:14:55 AM
Twincreek Twincreek is offline
Default Wagner Induction Repulsion Motor
Hello all. I have an old 3 hp Wagner induction repulsion motor that I use on a compressor. The motor has worked well for a long time but is now having trouble starting and coming up to final speed. I completely unload the compressor with a manual valve I added and it still has trouble coming up to speed. Once up to speed it will operate the compressor fine. Anyone have any suggestions on what needs fixed? My assumption is that it needs brushes and brush springs. Anyone know where to get these items? Any help you can give would really be appreciated. Thanks.
Old 09-21-2011, 10:48:00 AM
Elden DuRand's Avatar
Images: 6
Default Re: Wagner Induction Repulsion Motor
Without having seen your motor, I'll guess at the problem. Although it could be suffering from short brushes, it could just as easily have a greasy/dirty commutator or greasy/dirty/stuck brushes.
T'were it mine, I think I'd first do a good cleanup and check for high mica on the commutator. If that didn't do the trick, I'd throw some parts at it.
I have an older friend who, until recently, had an auto/tractor/mower repair shop. His big grinder was powered by an I-R motor. As long as I can remember, he had a trimmed broom handle to push on the brushes to get it up to speed. He told me it was less trouble to do that than to try to find new parts.
ON a compressor, though, I don't think that's a good idea.
Take care - Elden
Take care - Elden
http://www.eldensengines.com
Old 09-21-2011, 11:57:16 AM
Jerry Sweet Jerry Sweet is offline
There is a governor weight that lifts the brushes and short ciruits the commutator bars (connecting them together).there is springs and linkage that tie all this mechanism together.I would pull the ends off the motor and check the brushes,springs,linkage and ring.Clean it up and try it.The governor weights are on the shaft end, with a rod going to the brush end to lift the brushes and operate the shorting mechanism.The motor has a lot of starting torque and when it comes up to speed the bars are shorted together and the rotor becomes a squirel cage.To reverse the motor you just rotate the brush ring.Repulsion-start induction motors were replaced by high capacity,capacitor motors.
Repulsion-Induction motor jdunmyer Generators & Motors General Discussion 7 02-10-2010 11:51:14 AM
Repulsion Induction motor? tiptop Farm + Industrial Antiques and Collectibles 2 02-03-2010 01:02:50 PM
GE 2hp Repulsion Induction Motor torque454 Generators & Motors General Discussion 17 11-07-2009 09:50:24 AM
Repulsion start induction motor question Ned L Generators & Motors General Discussion 10 03-06-2009 08:32:57 PM
GE Repulsion-Induction Motor Roger Smith Generators & Motors General Discussion 11 10-02-2004 12:45:58 AM
