Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles
Farm + Industrial Antiques and Collectibles Old belt driven farm equipment: shellers, milkers, threshers, pumps and antiquities of the industrial revolution.
Whitman's Americus Senior Cider Mill
this thread has 14 replies and has been viewed 5478 times
Old 09-22-2011, 04:44:55 AM
skwimjim skwimjim is offline
Default Whitman's Americus Senior Cider Mill
Hi, new member here. I just brought this old (1880's?) Whitman's Americus Cider Mill back to life. From what I can tell, it's the "Senior" model having 17" diameter baskets. I am missing the crank, crank shaft, and big gear. Instead, I have a knicker knob mounted directly to the flywheel. "Crank faster, Johnny!". Does anybody have any information on these? I found some old advertisements, but that's about it. For those of you using this model, I'd like to know where you're sourcing your pressing bags. I see a few of you are looking for measurements as well. I'd be happy to provide whatever you're looking for.
The Following User Says Thank You to skwimjim For This Post:
Old 09-22-2011, 04:49:43 AM
Default Re: Whitman's Americus Senior Cider Mill
And here's a few BEFORE pictures:
The Following 3 Users Say Thank You to skwimjim For This Post:
Old 10-05-2011, 07:35:35 PM
Scott's Avatar
Scott Scott is offline
What does that gear on the inside of the flywheel drive?
Old 10-05-2011, 07:52:19 PM
Scott's Avatar
Here'a pic of a junior model with a crank handle. My junior model doesn't have any gears on this side and just a place on the flywheel for a crank handle. If anyone has a junior model for sale, I could use some parts.
Old 10-05-2011, 09:31:09 PM
Hank Czerwick Hank Czerwick is offline
We rebuilt a Red Cross press about 3 years ago. We've found that pressing without a bag and putting a sieve on top of the bucket is the way to go. You can even run a piece of linen in the sieve if you like. Much faster then messing with the bag and less stress on the press.
Old 10-27-2011, 07:13:25 AM
Hi Scott. The gear inside the flywheel is supposed to be driven by a larger gear (2:1 ratio?) that is connected to a handle on the other side. I'm missing that part, thus the knob attached directly to the flywheel.
Old 11-07-2011, 08:19:12 AM
Here are a few pictures from Saturday. We ran through about 700# of apples. Yield was 45 gallons of cider. We probably could have squeezed a little more out of them, but the 130 year old wood on the press was groaning under the load. I will probably have to replace the big upright timbers for next year. Who says you can't preserve history on a half-acre in the suburbs?
The Following 2 Users Say Thank You to skwimjim For This Post:
Old 11-13-2011, 12:14:00 AM
dbock dbock is offline
That is a good looking cider mill. I hope mine looks that good when I get it restored. I would like to get some dimensions of your press if you get a chance.
Old 10-30-2013, 08:33:23 AM
I replaced my uprights and cross-beam under the press end out of 4x6 white oak a few weeks ago as I blew out the uprights during a test-run. She should be good to go now. Due to repeated requests, I'm thinking of modeling up the wood bits in Google Sketch-up for distribution to all interested.
Old 11-01-2013, 10:22:22 PM
con-rad con-rad is offline
beautiful press! as for pressing bags, i used a $1.69 laundry bag from walmart and it worked great. at that price buy a few for extras!
conrad
Old 11-02-2013, 06:41:36 PM
Dutch Dutch is offline
Ditto - we The Ohio Valley Homebrewers [OVHA.net] also use these bags - they really work great.
We have moved to using a large meat grinder for the apples - that is a major speed improvement.
Old 11-06-2013, 09:44:22 AM
Emil K Emil K is offline
I would like to make apple cider next year, I'v never made it. I have an old big press, forget the name, but I'll check it out and post it. It has a lot of the orignal paint and pinstriping on it still. I have some questions.
Do you have to worry about the rust on the parts or what do you use to clean them. The rings on the baskets are rusty and the internal parts also.
How picky are you with the apples? do you wash the apples first? How do you presurve the cider?
Old 06-17-2014, 10:57:30 AM
I don't use apples that have more than a small brown spot on them or at least cut away and discard the rotted parts. I float the apples in tubs full of water to rinse, then press. When I got this press out of the barn, I fully disassembled it and removed rust with a wire wheel on a drill. I left the surfaces that touch the apples unpainted. Before pressing, I hose the whole thing down really good, inside and out. Then I run a couple of bushels of junk apples (deer apples) through it as the acid in the apples cleans the metal up real nice. Then I do another rinse with the garden hose before the main event.
---------- Post added at 10:57 AM ---------- Previous post was at 10:55 AM ----------
As far as preserving the cider, I freeze some of it in old milk/juice jugs in a deep freeze and make hard cider with the other portion.
Old 11-12-2015, 10:11:42 PM
dangrebe dangrebe is offline
I just purchased a complete double press that looks just like the one you have pictured. I think it is a Whitman's junior, but not sure. There is a Indian head in the center of the upper press casting, but no other cast features like, Whitman, or Junior on that casting or any other casting. There are numbers cast into the mill housing plates. The rest of the press looks like your Junior press pictured, except the press wheel has four knobs instead of three. I am interested in finding out if my press is a very early model. Does anyone have information about Whitman's design changes over the years or other information? My flywheel is 14" outer diameter, does this indicate if it is a Junior or Medium? The baskets are 9.5" ID. Sorry no pictures yet to share.
Old 11-13-2015, 01:19:07 PM
Maybe a couple of answers for you. First, the size of the buckets almost certainly indicates a "Junior" size. This was the smallest made. Next, the presses made by virtually everyone are very difficult to track. I have not seen a lot of manufacturing documentation keeping track of vintage. Primarily the casting parts (masters) were very difficult and expensive to replace. Therefore, very few changes were made to the masters and hence the cast part numbers did not change and give little clue to the age of the piece.
PM if I can be of any further help.
Whitman's Americus Cider Mill dbock Farm + Industrial Antiques and Collectibles 9 12-26-2013 11:43:07 AM
Keystone cider mill restoration LAS woodworking Farm + Industrial Antiques and Collectibles 4 09-21-2011 03:37:32 PM
Looking for information on old Whitman Americus cider press speedy Farm + Industrial Antiques and Collectibles 4 03-21-2011 10:53:03 PM
Cider Mill engines? RobDavis29 Farm + Industrial Antiques and Collectibles 2 03-31-2010 08:37:37 PM
Grain mill? (or cider mill) MarkL Farm + Industrial Antiques and Collectibles 19 10-30-2008 10:11:10 PM
