Steam Engines
Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Stationary Steam & Traction Engines
Stationary Steam & Traction Engines Antique steam engines, traction engines, their boilers and the related things that make them run.
This is one COOL Avery model!
This is one COOL model! :cool: Don't know if it's worth the starting bid.....but someone sure put a...
this thread has 9 replies and has been viewed 1609 times
Old 10-26-2011, 06:02 AM
Default This is one COOL Avery model!
This is one COOL model! Don't know if it's worth the starting bid.....but someone sure put a LOT of work into making one immaculate little model of an Avery engine!
http://ebay.com/itm/Vintage-Case-Avery-Steam-Engine-Tractor-Scale-Model-Scratch-Built-HUGE-/150681490291
Standard boilerplate-I know nothing of the seller, nor the item sold-just pointing it out as am sure some of the scale model steam folks will love to see it!
Mike M
Old 10-26-2011, 08:13 AM
David's Avatar
David David is online now
Default Re: This is one COOL Avery model!
Nate Lang, who built the half-scale Star Undermounted engine in the early 1960's, also made a very small, detailed Avery model. This may be that engine.
There is a picture of Lang's engine on the cover September-October 1954 issue of the IMA.
Looks like the same engine without a jacket, and the addition of extension rims. Also appears to have lost the headlight and the lubricator.
David
The Following 6 Users Say Thank You to David:
Old 10-27-2011, 06:52 AM
oldtractors's Avatar
Images: 5
It sure is a cool model. I notice that this one has the little steering wheel that changes the gears from low to high. I have been in some Averys that have the wheel, and some that just had a lever that switched from low to high. Which models had which?
Jim Evans
Old 10-27-2011, 07:17 AM
Dan Donaldson Dan Donaldson is offline
There is an air valve (tire valve stem) in the right hand coal bunker. Would this be used to run the engine on compressed air?
Old 10-27-2011, 07:25 AM
L Wilson L Wilson is offline
Mike M
The same seller had a highly detailed Case 75 model a few months back, This is all from the same estate. The case was extemely high quality, Insert SS boiler, hand feed inj. pump, steam pump, hidden pres. gauge in the tinder box!. No castings any where. The relief valve and whistle had cut outs in the canopy that was the only none original appearance part about it. LW
---------- Post added at 07:25 AM ---------- Previous post was at 07:22 AM ----------
David
David, Its time to blow some whistles'! LW
The Following User Says Thank You to L Wilson:
Old 10-27-2011, 11:57 AM
JBoogie's Avatar
JBoogie JBoogie is offline
Images: 241
Lester Roos of Freeport, Ill built an Avery I think. He was a toolmaker (or something) for Stover gas engines.
Old 10-27-2011, 01:08 PM
FWurth's Avatar
FWurth FWurth is online now
As I recall Lester had the remains of the Stover Engine co and for many years supplied all parts for a wide variety of Stovers to the hobby. We met him many years ago at a show in northern Il. a very helpful person. Someone else has taken over his enterprise but I can't recall who. F.J.W.
The Following User Says Thank You to FWurth:
Old 10-27-2011, 01:13 PM
hhall's Avatar
hhall hhall is offline
Here is an old article about Lester, he used to have the Avery at Mt. Pleasant when I was young. it was pretty neat, had a propane tank under the seat of the little cart that he set on while running the engine for fuel.
http://gasengine.farmcollector.com/F...ER-L-ROOS.aspx
The Following 3 Users Say Thank You to hhall:
Old 10-29-2011, 12:35 PM
Steve Kunz's Avatar
Well the Auction is almost over with no bids yet.
Mike M
Your right Mike it is really COOL. If I had an extra pile of money laying around you know what my next toy would be!
The starting bid does seem high but if I owned it I dont know if I would sell it for any less myself, its just to cool. That is if it is as good as it looks. Hopefully it will find a good home.
Steve
The Following User Says Thank You to Steve Kunz:
Old 10-30-2011, 10:13 AM
johnk907 johnk907 is offline
David
Do not think this is the engine you are refering to. I believe this is a picture of Lester Roos and his Avery. John
---------- Post added at 09:13 AM ---------- Previous post was at 09:07 AM ----------
You are so right. It is a masterpeace of workmanship. He always displayed it up a ramp on a table so you did not even have to bend over to admire it.
John
Minneapolis Moline Avery Model V Candy T. Antique Tractor Talk 12 01-19-2011 11:04 AM
Model 15-30 MD and Avery thresher Tom Cwach Scale Model Engineering 4 02-04-2008 08:08 AM
Cool Cannon model find at one of my favorite places to go. Paul Spence Antique Gas Engine Discussion 13 11-19-2007 01:03 PM
Cool Windmill model find at one of my favorite places to go. Paul Spence Vintage Toy Steam Engines and Motors 6 11-15-2007 12:38 PM
