Is this a chainsaw engine? (Power Prooducts)
this thread has 17 replies and has been viewed 5385 times
Old 11-05-2011, 03:54:19 AM
haystack haystack is offline
Default Is this a chainsaw engine? (Power Prooducts)
Has no ID tag or anything im confused on what it is!
Old 11-05-2011, 07:53:35 AM
MCanady's Avatar
MCanady MCanady is offline
Images: 39
Default Re: is this a chainsaw engine?
Looks like a dirt tamp or jumping jack engine. Merton
Old 11-05-2011, 08:43:26 AM
Briggs Man's Avatar
Briggs Man Briggs Man is offline
Photo Re: is this a chainsaw engine?
I'm not sure what manufacture the engine is, however it looks to be relatively complete. I've got a few 2 cycles in my collection and I would suggest making it pretty, fabricating a mounting bracket, attaching it to a board and displaying it.
If nothing else it would be a nice conversation piece (and I'll bet that eventually you'll find out what it is).
A few mounting ideas (see pics)..
Chrome 2 cycle 009w.jpg   Engine Display Plaques 006w.jpg   Mounting Brackets.jpg
"The beauty of the 2nd Amendment is that it will not be needed until they try to take it away" -T.J.
Old 11-05-2011, 08:58:49 AM
QuickJ QuickJ is offline
The engine is a "Power Products" 2 Cycle
They were used on a bunch of different stuff. This looks like it could have been on a mower deck with the exhaust poking down through the deck.
Old 11-05-2011, 03:09:56 PM
Exclamation Re: Is this a chainsaw engine? (Power Prooducts)
The engine, as you have it pictured in both of your posts, is upside down! Looking at the carb, the fuel bowl is inverted! That type carb and filter were typical for chain saws. The engine may not be a 1000, as typically, the 1000 had a governor mounted on the crankshaft, near the block, on the power take off side. It was installed under a housing that was mounted on the block. I see no linkages on the engine. Chainsaw engines typically were direct throttle, no governor. The way the carb is mounted, the shaft is horizontal
Old 11-06-2011, 02:06:50 AM
Default Re: Is this a chainsaw engine? (Power Prooducts)
i know its upside down. I to think it is a chainsaw motor cause ther is no linkage like you said and Ive seen chainsaws with this engine only thing is the carb comes straight out with no elbow but that could also be the way the chainsaw was made
Old 11-10-2011, 01:18:54 PM
sprkplug sprkplug is offline
Power Products were used quite a lot on the David Bradley chainsaws.
Old 11-10-2011, 03:04:47 PM
Ive been doing some research mcculloch used em to and this one is mcculloch yellow matches up to my other one still researching tho
Old 11-15-2011, 10:23:40 PM
gvasale gvasale is offline
a power products engine has shown up on craigslist (Massachusetts)today. don't remember if is worcester, or boston. Looks complete, and as a v belt pulley. $75 is the asking price. Even has the all metal label.
Old 01-27-2012, 11:46:11 AM
Adirondackstihl Adirondackstihl is offline
Looks like a Mac Kart engine if ya ask me
Old 01-27-2012, 01:31:21 PM
IronHead IronHead is offline
Could have been on a post-hole digger or even been a small outboard marine engine. Lausen had a very similar air-cooled outboard motor,but it was a 4 stroke. Just a guess, Thomas
Old 01-28-2012, 10:08:13 PM
Clayon Clayon is offline
Ya, it looks like a McCulloch karting motor to me. What kind of carb is on it?
Old 03-03-2012, 08:55:29 PM
caporal30 caporal30 is offline
It is indeed a PP(Power Product) chainsaw engine. Tecumseh sold them for many branded saws. The missing frame close to the crank, would attached tank and chain/bar. They were often use in karting. on the pictures, the engine is upside down because I can see the Tillotson MD carburator float style with the float bowl up in the air.....
Alain,
with this yellow color and missing recoil, I can see on the flywheel that it used a clutch teeth "Schnackle" recoil, not the standard FM or Bulldog type.....
I am guessing that this saw was a "Fleetwood" model 400....but I can be wrong....
Old 03-17-2012, 09:05:51 AM
Here is a Mac SP125/101B
Pic is of a fellow member on another forum.
We had a GTG last weekend down around Saratoga.
Old 03-17-2012, 09:08:01 AM
Heres a Mac Super 797
Old 03-17-2012, 04:44:30 PM
mcbob mcbob is offline
Nice Macs i feel even though the 125 wih a 101 sounds good i personally dont think it would cut any quicker than a stock SP125 the intake is the biggest restriction to a performance boost thats why the 101 has a BDC carb at 35mm
McBob.
And once the airfilter cover is back on no-one knows.
Old 12-07-2012, 12:30:41 AM
junkitis junkitis is offline
DEFECTIVE EMAIL ADDRESS
Hello. Your engine is a Homelite 24x1 from an early David bradley 3-16 chainsaw. In theese early days they were kin to Lombard and in some instances they were Lombard. They were also painted red and sold as the Strunk Eager Beaver. In 1951,Bradley and Lombard switched to the Power Products AH47. Your Homelite engine was also used in Poulans first chainsaw,along with others,before Homelite got in the chainsaw game for themselves. The engine case on the AH47 in a dead knockoff of the Homelite 24x1. The AH47 was used in every kind of chainsaw made in North America except for the big name manufacturers-pardon Lombard-to great success for all. If you guys playing with AH47s over-rev them,be carefull-the flywheels will explode. I had one come apart due to a small crack in the key way. Three broken fingers and 29 stitches later,I took a magnifying glass and looked at the pieces,and found the evidence. See ya. Junkitis.
The Following User Says Thank You to junkitis For This Post:
Old 12-07-2012, 12:37:57 PM
bigGURN bigGURN is offline
Images: 1
I'm unaware of any McCulloch using a Power Products engine... McCulloch prided themselves in the production of their own engines until the late 70's and beyond when Paxton was out of the picture, but by the Power Products was out of the picture and it was Italian and other Foreign saws that where re-branded McCulloch
O&R chainsaw mccullochman Chain Saw Collectors 7 12-03-2014 07:34:09 PM
chainsaw mccullochman Chain Saw Collectors 1 07-20-2013 05:52:02 PM
Info Needed on Power Products Chainsaw Jscatt Chain Saw Collectors 1 01-18-2010 07:48:47 PM
Power Machinery Vancouver BC chainsaw Peter Chain Saw Collectors 6 07-28-2009 07:41:31 PM
Chainsaw (featherweight west bend engine) Steve Kreiner Chain Saw Collectors 2 05-10-2008 06:27:28 AM
