Garden Tractors / Mowers / Scooters Vintage lawn and garden tractors, mowers, snowmobiles and other old machinery that is driven by small air cooled engines.
Briggs & Stratton
this thread has 4 replies and has been viewed 1781 times
Old 11-23-2011, 08:42:20 PM
MotorPower MotorPower is offline
Default Briggs & Stratton
Can someone tell me the Hp. of this motor ?? I have a Model 9FB Type 201537 Serial # 99989 it is in a Bantam tractor .. Thank you for the help .. Have a happy Thanksgiving to all !!!!
Old 11-23-2011, 09:32:46 PM
1938Sears 1938Sears is offline
Default Re: Briggs & Stratton
I believe it is around 2-1/2HP, based on the book rating of 1.70 HP at 1800RPM and 3.35 HP at 3600 RPM. Hope this helps.
The Following User Says Thank You to 1938Sears For This Post:
Old 12-04-2011, 06:32:37 PM
dw1973 dw1973 is offline
3hp. I have a Standard (pre-Bantam) with a Briggs 9FB.
Old 12-05-2011, 11:02:39 AM
K D Redd K D Redd is offline
Your engine uses the Briggs Magnematic Magneto. If your engine runs well at idle BUT when you throttle the engine up it starts to miss and sputter, you will think you have a problem with the carb. You Do Not have a problem with the carb. You have a bad coil. The coil, Briggs P/N 290880 is no longer available from Briggs. You can buy one from Small Engine Warehouse that is made in China. I have NOT used one of these coil BUT from what I have read on-line their quality is somewhat hit or miss. I modify a later Briggs coil to replace the 290880 coil.
Kent
Old 12-05-2011, 02:16:52 PM
sprkplug sprkplug is online now
If you have a bad coil you might also try going to your local Napa, and ordering part #7-01604, which is a replacement, probably Chinese, for the Briggs 290880. It is a special class from Napa, so it might take a couple days to get it in. Retails for around $111.00....... this is a Primeline part, should be the same one sold at Small Engine Warehouse, and O'Reilly's Auto Parts list it for around $70.00 (in my area), with a limited one year warranty.
Briggs & Stratton krazzyp Small Air Cooled Gasoline Engines 9 05-10-2011 01:48:37 PM
Briggs & Stratton AG & AGR SBreeden Small Air Cooled Gasoline Engines 14 05-12-2010 01:34:57 AM
Briggs & Stratton NPW hitnmiss Small Air Cooled Gasoline Engines 3 03-26-2009 02:58:39 PM
Briggs and Stratton Mark Mohney Small Air Cooled Gasoline Engines 9 12-29-2007 09:08:09 PM
Briggs/Stratton Alan Fannin Small Air Cooled Gasoline Engines 4 06-19-2005 12:02:55 AM
