Onan 7.5 JB armature removal question
this thread has 6 replies and has been viewed 1325 times
Old 12-16-2011, 05:36:01 PM
Don Smith
Default Onan 7.5 JB armature removal question
I am in the process of tearing down my Onan 7.5 JB with the bad block. About to remove the armature from the crankshaft. Does the JB series have the same crankshaft taper that is used on most RV type Onan generators? What is the best way to break the armature free from the crankshaft. It is a Magnaciter type generator head. Thanks in advance and Merry Christmas to all. Don
Old 12-16-2011, 06:42:54 PM
Billy J Shafer's Avatar
Default Re: Onan 7.5 JB armature removal question
Remove the center bolt. Then lay something under the rotor to catch it. So that you don't damage the windings. Then you can use a board on the shaft of the rotor. Hit it with a hammer,then rotate it and hit it again. It should drop off. Just make sure the board is not on the bearing or the windings. Also avoid hitting the slip rings.
Old 12-16-2011, 07:31:32 PM
Billy makes it sound so easy, of course he has done it many times. I found I needed to repeat those steps several times & used a board & a BFH to smack the side of the rotor many times. As Billy said, be sure you support the rotor with blocks or a sling, because when it does come off, it may be all at once.
The Following User Says Thank You to Max Thompson For This Post:
Old 12-16-2011, 07:36:53 PM
Don Smith
Hi Billy Thanks for the email. I have the center bolt still in place but without the nut. That should keep it from slipping off completely. If my memory serves me correctly I should hit it around the main body of the armature. At a right angle to the shaft. Is this correct? Did not want to damage the shaft or slip rings. Thanks Don
Old 12-16-2011, 07:44:11 PM
Remove the stud from the center. I have seen them break from the weight of the stator. Hit the shaft you will not hurt it.
Old 12-17-2011, 03:45:12 PM
Don Smith
The armature popped off like a dream. Found that one must use a larger hammer to transfer enough energy to pop it loose. Flywheel removal next on the list. Thanks Billy and Max. Merry Christmas
Old 12-17-2011, 03:57:05 PM
Forgot to tell you. As our stackers from the UK say. You need a big Fooken Hammer.
The Following 2 Users Say Thank You to Billy J Shafer For This Post:
J mag armature removal Allan Wright Magnetos, Ignition Coils and Spark Plugs 4 10-14-2011 04:35:32 PM
Magneto Armature Removal Jordan Magnetos, Ignition Coils and Spark Plugs 5 04-27-2011 11:08:37 PM
Armature removal 7.5 A27 little river Kohler Generators 7 01-24-2009 06:02:36 PM
Low Tension Mag Armature Removal waterpowered Magnetos, Ignition Coils and Spark Plugs 1 04-07-2008 08:56:27 AM
5CCK Armature removal Mat Phelps Onan Generators 8 01-02-2007 01:52:14 AM
