Kohler Generators
Kohler 7.5C62 voltage falls off while running
this thread has 0 replies and has been viewed 1268 times
Old 12-18-2011, 11:03:25 AM
Dtarsi Dtarsi is offline
Default Kohler 7.5C62 voltage falls off while running
Generator starts well and runs about 15 minutes on 1/2 load. Then the voltage goes to zero, dumping the load. Generator remains running. After a short time the voltage comes back and load is re-established. Again it goes thru the voltage drop scenario. Before this happened the generator seemed to slightly hunt at load and I could see a slight varying of voltage and frequency. Found from Kohler that the price of a new regulator kit was around $500. Don't make the original type. They also, said that Kohler no longer supports the alternator and the voltage regulator gets an AC input from the stator. Has anyone experienced this problem? Is it probable that this is a regulator problem or heaven help me, a stator problem? Thank you.
Kohler 7.5c62 LP powered; Choke Question mobus1 Kohler Generators 4 07-04-2010 05:20:57 PM
Kohler 7.5c62 generator info wanted mobus1 Kohler Generators 0 06-21-2010 10:43:37 PM
Parts and manual for Kohler 7.5c62 surviverguy Kohler Generators 4 01-19-2009 07:29:56 PM
Kohler 7.5C62 needs choke to start on propane eeleater Kohler Generators 6 10-31-2007 08:58:09 AM
Kohler 7.5C62 Owner's Manual Dtarsi Kohler Generators 4 08-14-2005 11:54:22 AM
