| Antique Gas Engine Discussion Meet collectors of hit and miss engines, ask questions about collecting, restoring and showing antique flywheel engines. |
Ignitor points?We would like to make new points for a ignitor. Has anyone done this and how did they work for you?...this thread has 5 replies and has been viewed 752 times
We would like to make new points for a ignitor. Has anyone done this and how did they work for you? What type of steel should we use? thanks
Bob Ronning http://www.oldengine.org/members/sandwich/ |
Use platinum so it won't corrode. Actually Lee Pederson has them already made cheap. I've used a couple of sets and they worked fine.
The Following 2 Users Say Thank You to John Hamilton:
Use low carbon steel. A large common nail or rebar works good for me. Made lots of them. Most points are just light pressed in and peened over on the back side. To remove, just grind off the peened area and punch out the old points and install your newly turned points and peen them over like the originals. Some ignitors have a tapered shaft I have found and this takes a little more machine work but is easily done.
The Following User Says Thank You to Heller D. Davis:
While working on a Miami ignitor i discovered the points were tapered
so i checked to see if a taper pin would fit.It fit perfectly and the pins made a great set of points after grinding them to length.With a set of taper pin reamers and an assortment of pins one could easily renew the points in most ignitors.They could then be easily changed in the future as they fit nicely with no peening necessary. |
I had to replace points during a show, used a piece of allen wrench.
TH |
Nickel works well and wont rust. Db.
| New points into an ignitor. | GregSenn | Antique Gas Engine Discussion | 4 | 07-07-2006 12:24 PM |
| Ignitor Points | Keith | Antique Gas Engine Discussion | 2 | 10-21-2005 07:55 PM |
| ignitor points | tim rostar | Antique Engine Archives | 3 | 09-22-2004 04:44 PM |
| Points gap for ignitor | Kent Zobel | Antique Engine Archives | 1 | 12-12-2001 12:54 PM |
| ignitor points | Juffer | Antique Engine Archives | 3 | 08-16-2001 09:03 AM |
