Air cooled engine fuel pressure?
this thread has 4 replies and has been viewed 3194 times
Old 12-27-2011, 02:47:40 PM
Motorhead's Avatar
Motorhead Motorhead is online now
Default Air cooled engine fuel pressure?
What is the fuel pressure for a small engine that uses a mechanical fuel pump? 14 hp Wisconsin is what I am working on. I want to put on an electric Facet cube pump. They make them in varying fuel pressures.
Old 12-27-2011, 03:08:07 PM
Exclamation Re: Air cooled engine fuel pressure?
1 to 2, PSI, 3 tops. It doesn't take much to overide the float on a small engine. If you get a fuel pump that puts out too much pressure, several manufacturers make fuel pressure regulaters for various uses.
Old 12-27-2011, 05:27:56 PM
Motorhead's Avatar
Default Re: Air cooled engine fuel pressure?
Thanks Andrew. I was thinking under 3psi but wanted a second opinion.
Old 12-27-2011, 07:10:31 PM
sprkplug sprkplug is offline
Kohler makes an electric fuel pump kit for their engines. It's part # 25-559-01-S. When you open the genuine Kohler box, you will find a genuine Facet pump, part #40177. It's .5 to 2 psi. I have put them on all manner of small engines, including Kohler, Briggs, and Kawasaki.
I no longer order them from Kohler, however. I don't feel the need to pay someone to put that facet pump, still in its box, inside a Kohler box. Cheaper to get them direct.
Old 12-27-2011, 08:23:45 PM
Motorhead's Avatar
Thanks... If all else fails then Kohler will do. My NAPA store is working with me to try to get a Facet pump direct from the mfgr.
Although the STOCK mechanical pump is weak, I checked the fuel pressure while the engine was running and it ran .5 to 1 psi. Thanks for the help guys!
2-71 loss of fuel pressure from fuel tank-check valve? or bad fuel pump? Walter J. Generators & Motors General Discussion 18 08-24-2011 09:22:40 AM
Wisconsin V-4 fuel pressure farmer24 Wisconsin Engines 4 01-19-2010 06:35:02 PM
Too much or too little fuel pressure flasks Antique Gas Engine Discussion 16 01-25-2009 01:23:40 PM
Need fuel tank - air cooled engine that runs a corn detassler 20minnie Small Air Cooled Gasoline Engines 5 01-13-2009 02:26:31 PM
Low Pressure Fuel Pump jnorton Onan Generators 2 07-19-2007 08:40:53 AM
