Kohler Light Plant Parts
this thread has 15 replies and has been viewed 1678 times
Old 02-14-2016, 09:18:06 PM
grub54891's Avatar
grub54891 grub54891 is offline
Default Kohler Light Plant Parts
my son is re-doing a 1945 Kohler light plant motor. As of now it has great spark, but no compression, so he tore it sown, and found broken rings. Anyone have a source for rings/gaskets??
Old 02-14-2016, 11:10:32 PM
Default Re: Kholer light plant parts.
Check the sponsor page for Otto Gas Engine works for piston rings.
Old 02-14-2016, 11:34:25 PM
grub54891's Avatar
ok, thanks. i'll have a look
Old 02-15-2016, 01:14:54 AM
George Andreasen George Andreasen is online now
Be aware that those Kohlers didn't have a lot of compression, even with good valves and rings so don't be surprised after the rebuild. They're only four horsepower and designed for low stress longevity.
Old 02-15-2016, 08:02:40 AM
grub54891's Avatar
Yeah George, we get that, they were low compression motors. It was so low it would fire on number one but nothing else, the mag has huge spark on all cyl. He found broken rings on the pistons. As far as we know it sat in a shed for at least 20 years. Maby that was why....
Old 02-15-2016, 10:03:09 AM
Good deal! I know your son is going to enjoy it when it's up and running. They are a very "useful" antique!
Old 02-15-2016, 10:19:46 AM
BHoward BHoward is offline
I have some good pistons and rod bearings if you need any. Bill H.
The Following 2 Users Say Thank You to BHoward For This Post:
Old 02-15-2016, 09:23:49 PM
grub54891's Avatar
Thanks guys, It does not have the generator head on it, must have been removed years ago. It is set up with a jackshaft to a water pump, probably to pump from a pond or watering cattle?? My son is going to re-purpose the unit, we just don't know what yet.
Old 03-14-2016, 06:33:51 PM
49panhead 49panhead is offline
Hi we have a 1 1/2 kw kohler d.c. generator 1937 at our cottage. This winter it started knocking bad I need to find a set of connecting rod bearings (crankshaft end) it would be great if anyone knows where I might find a set.
Old 03-14-2016, 10:02:35 PM
I have a set of rod bearing. How is your crankshaft. I have one of them as well . Bill H.
Old 05-14-2019, 09:18:01 AM
old briggs restorer old briggs restorer is offline
Is there any chance you still have those pistons? I'm rebuilding one of these and one piston was rusted in the cylinder so bad that I broke it in half trying to remove it. I cant find even a used piston anywhere, and I really don't want to have to part the rest out.
Old 05-14-2019, 06:55:19 PM
Look in my old posts about kohler generaters, and have a look for A-1 services. They might have a source for pistons.
Old 05-15-2019, 09:25:56 PM
grub54891's Avatar
Default Re: Kohler Light Plant Parts
I know it's been a few years, but just recently my son found another light plant, with the generator head. We picked it up two weeks ago. The motor is stuck, but he's soaking it to free it up for disassembly. Between the two, he just might get one running. I hope so!
And a late thanks to Bhoward for the offer of the bearings. Ours look pretty good.
Old 05-16-2019, 09:34:43 AM
How exactly do i contact A-1 services? i looked in some of your older posts, but i still don't know where to go.
Old 05-16-2019, 11:49:51 AM
The last info I have for them: Lee Wright, A-1 Engine services 847-678-5499. his father Ed Wright had many NOS old kohler parts and info. Not sure if he is still on the Stak, he used AOneEngine Not sure if info is current, you might check with Amish Acres here on the Stak- Don Wright as well.
Old 06-23-2019, 08:31:13 PM
grub54891's Avatar
deleted. have to figure out how to get the video up.
Kohler Light Plant Parts on eBay Mike G Kohler Generators 4 02-06-2013 10:26:27 PM
I need Kohler Light Plant engine parts kain Kohler Generators 0 08-15-2011 04:27:38 PM
kohler light plant ehpower2 Generators & Electric Motors General Discussion 0 10-25-2009 10:30:53 PM
Kohler Light Plant ( 3.5 R 22 ) Carl Hangey Kohler Generators 1 10-12-2008 05:19:40 PM
Kohler light plant trials20 Kohler Generators 0 01-22-2004 11:47:37 PM
