Running a Generator With No Muffler
this thread has 19 replies and has been viewed 686 times
Old 01-06-2018, 09:08:51 PM
KPack KPack is offline
Default Running a Generator With No Muffler
When testing a generator how long can you run it without a muffler or is it bad to do it ?
Old 01-06-2018, 09:15:58 PM
len k len k is offline
Default Re: Running a generator with no muffler
Till your ears bleed, or neighbors come with pitch forks. Over summer ran my JB without a muffler didn't think it was that loud , till I saw my neighbor and his wife starting hard at me from their deck..... that they had to get a variance to build closer to my property line than zoning allows.
I suspect it's not a problem, except for your ears. I suspect muffler only makes a small bit of back pressure that's pretty small compared to the high pressure in cylinder. So it shouldn't have any significant effect on exhaust flow rate , for heating exhaust valve. Think muffler only adds maybe 2 ?? psi backpressure, think cylinder pressure is 150-450 psi while burning.
The Following 2 Users Say Thank You to len k For This Post:
Old 01-06-2018, 09:40:54 PM
consolenut consolenut is offline
Well from what I know of car engines. Its not good run an engine without a muffler long term. Unless its designed too. As its possible to burn a valve. Just my opinion.
Old 01-06-2018, 09:50:17 PM
Email NOT Working
https://www.youtube.com/watch?v=jjPeP_Nn2B4&t=157s
Old 01-06-2018, 10:09:18 PM
It's not so much the lack of muffler that causes valve issues, it's the length of the exhaust opening away from the valve... if you remove a muffler and run with just the short port, air reversion can cool a hot exhaust valve causing thermal shock, if you add a short length of pipe to prevent this reversion you should be fine.
The Following 4 Users Say Thank You to AngrySailor For This Post:
Old 01-06-2018, 10:55:08 PM
What Len said.
Old 01-06-2018, 10:59:43 PM
Gunny Gunny is offline
No issues. I've run a lot of them on load banks for up to 24 hours with no mufflers (silencer) at 100% load. A Cat 3516 had an orange flame about 2' standing out of the flower pot at night.
The engine may run a little more efficiently with a littl eback pressure on the exhaust, depends on the cam profile. Have run motorcycle engines with no exhaust at all, right out of the head, never burned or warped a valve. Made some ears hurt.
The Following 3 Users Say Thank You to Gunny For This Post:
Old 01-07-2018, 07:58:39 AM
lokay5's Avatar
lokay5 lokay5 is offline
Just an old urban myth.
An engine would be more likely to "burn" a valve with a muffler.
"...air reversion can cool a hot exhaust valve causing thermal shock"
Urban myth
1973 CK5 Blazer
The Following User Says Thank You to lokay5 For This Post:
Old 01-07-2018, 08:25:32 AM
Handyhiker1 Handyhiker1 is offline
Default Re: Running a Generator With No Muffler
On a constant speed engine it is not going to hurt anything. When the RPM drops suddenly that is when the possibility to suck cold air back into the exhaust and damage the hot exhaust valve.
Old 01-07-2018, 09:47:28 AM
BRae's Avatar
BRae BRae is online now
The engines efficiency may change some however, I doubt it will damage anything but your ears.
The Following 2 Users Say Thank You to BRae For This Post:
Old 01-07-2018, 09:49:58 AM
Wow I donít know what to say.
https://m.youtube.com/watch?v=OpXwzbZ95hY
Old 01-07-2018, 12:47:05 PM
Jim Marcozzi Jim Marcozzi is offline
The whole "burn a valve" thing because of back pressure or reversion is a myth.
The REAL reason that a valve can burn is that if your fuel mixture is set WITH a muffler in place and now you remove it, you will create more air flow through the engine at higher given throttle opening at load because of a lower back pressure, which makes your (once good) mixture now lean. Lean = heat. Prolonged lean running can and will damage a valve. It has nothing to do with cold air sucking in or any of the other BS that float around the internet or is spewed by hot rodders from 50 years ago.
The whole "an engine needs back pressure" thing is not true. When you hear someone complain that they changed the exhaust on their car and now it runs worse, someone always makes the claim that it needs back pressure to properly run. What it really needs is the mixture under load corrected for the additional air flow.
Ideally, I'd set the mixture on a genset at 100% load by using a pyro in the exhaust ports and going by EGT and also 4 gas analysis, but this isn't realistic, nor is it my car that I run 28 PSI boost on with good fuel. If you open the genset's exhaust or even change mufflers, I'd always recommend readjusting the main carb jet or gaseous flow as per manufacturer. Anyone who races a 2-stroke dirt bike can tell you the importance of readjusting the fuel for even the slightest exhaust change or even cleaning the muck out of the muffler or expansion chamber and making more high load airflow.
TUNED equal length and volume headers, 2-stroke expansion chambers, H-pipes and other exhaust trickery can actually make negative exhaust pressure on an exhaust port and aid in drafting more air into an engine. Not only do these engine see no back pressure, but they have exhausts under a slight vacuum with operating at a specific RPM range. That's also known as the "powerband" in the 2-stroke dirt bike world.
I've dealt with this over and over in the earlier days of EFI injection on 5.0 Mustangs, IROCs and TPI Vettes. Everyone was convinced that these cars needed BP to run properly since most gear heads at the time knew zero about EFI and how to tune it. I was one of the few that actually knew how to recal the MAF and even eventually was able to change data and re-flash new PROMs to correct the fuel on the GMs.
Any internal compression combustion engine is always more efficient with no (or negative) back pressure, but fuel and timing have to be adjusted properly, as with any engine.
So go ahead and straight pipe it, but make sure it's adjusted properly. I'd also invest in some Kevlar through if you have close neighbors !
The Following 4 Users Say Thank You to Jim Marcozzi For This Post:
Old 01-07-2018, 01:23:37 PM
Of course the mixture must be maintained but have you ever tried placing a wide band O2 sensor within about a foot of the end of a header collector and tried to get a stable reading? Reversion is most definitely happening and will be dependant on the cam profile and induction to a degree.
Old 01-07-2018, 01:37:10 PM
Reversion IS happening but it has nothing to do with burning or damaging a valve. It's relevant to cylinder scavenging and the size/area of the peak power band.
The Following 2 Users Say Thank You to Jim Marcozzi For This Post:
Old 01-07-2018, 02:26:28 PM
I know this is an Onan generator sight BUT, The knowledge on this Onan sight it overwhelming in reguards to "performance" minded people.
I klnow there is a general discussion heading here on the STAK , however it would be KOOL if there could be a "Engine/Car/Motorcycle "Performance" discussion area!
The Following User Says Thank You to nothingbutdarts For This Post:
Old 01-07-2018, 03:15:09 PM
Headers on race cars are tuned to make a vacuum at exhaust valve to increase air flow. So I don't think back pressure is needed.
On a 2 engine 10 passenger commuter airplane flight I took once at dusk. I saw engine had ~ 3-4 feet of exhaust pipe with no muffler, glowed dull red entire flight. Seems no muffler was obviously for power and weight reasons, looked factory. Besides FAA would have a fit if owner modified it.
Odd that carb can't maintain steady air/fuel mixture if change backpressure (remove muffler) Maybe it's just a quirk of carbs. But would think as increase airflow more fuel would be drawn thru main jet
Old 01-07-2018, 05:28:57 PM
Newoldstock Newoldstock is offline
All exhaust systems add some back pressure.
When you reduce this you increases the amount the engine can suck on the carb and you will lean out the carb.
This is physics and not in dispute, what is likely to colour your view of this is is how rich or lean you carb was from the start.
Cold shock can bend valves if the exhaust port is open.
Even if it is not there is a possibility of an overheated engine behind a valve if you run a cold exhaust ( thin header pipe and no warp ).
This almost never happens in practice because the engines we are talking about here have small valves, small ports, small exhaust and usually a lot of iron to hold some of that heat for a uniform cool down.
I have had some troubles with some very expensive stainless valves in some very large free breathing engines with short open exhaust.
Solution is make sure both valves are sitting on a seat for cool down.
Open headers.
My neighbors do not like loud engine noises so I try not to run any engines around here when they are outside and can clearly identify me.
Old 01-07-2018, 06:23:48 PM
lokay5's Avatar
Originally Posted by brae View Post
the engines efficiency may change some however, i doubt it will damage anything but your ears.
........whaaaat? ? ?......
1973 CK5 Blazer
Old 01-07-2018, 07:11:28 PM
It is a pumping loss.
So it will impact efficiency.
Old 01-07-2018, 11:35:44 PM
JoeE. JoeE. is offline
Along these same lines, I ran a locomotive yesterday... I think it was a 12 cylinder... diesel...
At idle, all sounded normal. As I put a load on it... get the RPM up to about 700, a whooshing sound like the exhaust of a steam locomotive came out from under the hood... and got louder and louder... if I let off the throttle it would lessen, but would come back on when I came back out on it...
Finally, set the brakes tight and put the throttle in 2 and ran out and opened the doors on the body...
I was surprised to see that one of the exhaust manifolds had broke loose from the exhaust port on the number one cylinder... and while the broken part was still attached to the "muffler", the exhaust gasses were forcing it away from the head.. and the noise was deafening in there... soot covering everything...
Heck, it rolled in here, it can roll out.. we'll let someone else worry about it!
The Following User Says Thank You to JoeE. For This Post:
18hp briggs vangaurd powered Generator running on propane running rich. bugman53 Generac Generators (SEARS, etc.) 1 02-16-2016 02:48:38 PM
Muffler for Generac NP-66G M/N 09600-2 RV generator timrauch Generac Generators (SEARS, etc.) 3 12-03-2014 04:04:03 PM
Better muffler for Kubota D905 powered generator Joe Romas Generators & Electric Motors General Discussion 8 05-17-2012 10:01:28 AM
Detect generator running? Isaac-1 Generators & Electric Motors General Discussion 6 12-21-2010 05:58:24 PM
Onan stock muffler 155-1258 or cheap Car muffler(s) HondaBob Onan Generators 2 01-21-2010 08:03:48 PM
