Onan 2.5LK Factory Enclosed. Installed Gauges. Now like Contractors Model
this thread has 6 replies and has been viewed 347 times
Old 01-11-2018, 11:38:38 PM
Motorhead's Avatar
Motorhead Motorhead is online now
Default Onan 2.5LK Factory Enclosed. Installed Gauges. Now like Contractors Model
I am in between my Back surgery, December 12th, 2017 and my Knee replacement coming Jan. 22, 2018.
I needed something to occupy myself but not heavy lifting. I have my May, 1972 Factory enclosed, 2.5LK that I did a mechanical restoration on and I wanted gauges in behind the door on the enclosure. All there was was the start-stop switch. I installed a rebuilt Hz, new volt meter and a new ammeter.
I used some of the same LEDs that I used to light the gauges on my JB control panel by using a piece of 1" Aluminum "C" channel and drilling it for the LEDs.
I found a proper delay, Airpax, 20 amp Full load, 25 amp trip circuit breaker.
The duplex plug box with the BELL weather cover was already mounted. I just put a new 20 amp duplex plug receptacle and I will probably add another. Only have about 21 amps to play with and the set is a 120 volt only.
You will notice blue masking tape on the gauge faces. This made handling the assembly easier and saved the plastic lenses from getting scratched.
Name:	IMG_3670 (1280x960).jpg
ID:	300254   Click image for larger version
Name:	IMG_3672 (1280x960).jpg
ID:	300255   Click image for larger version
Name:	IMG_3673 (1280x960).jpg
ID:	300256   Click image for larger version
Name:	IMG_3674 (1280x960).jpg
The Control panel
and gauges of my
7.5JB
Old 01-11-2018, 11:44:28 PM
Motorhead's Avatar
Default Re: 2.5LK Factory enclosed. Installed Gauges. Now like Contractors model
Last 4 pictures.
The Hz gauge was a used one I bought on ebay, two of them for $9.99 free shipping. Only one worked and the other had a bad resistor. The cases were beat up so I transferred the internals into a brand new case and face from an ammeter I bought not knowing what I was buying at the time that took a weird style current transformer. So it became the donor.
The 1800 rpm LK almost sounds like a hit and miss engine because it runs slow and chugs along.
Name:	IMG_3675 (960x1280).jpg
ID:	300259   Click image for larger version
Name:	IMG_3676 (1280x960).jpg
ID:	300260   Click image for larger version
Name:	IMG_3677 (1280x960).jpg
ID:	300261   Click image for larger version
Name:	IMG_3678 (1280x960).jpg
The Control panel
and gauges of my
7.5JB
The Following 7 Users Say Thank You to Motorhead For This Post:
Old 01-11-2018, 11:50:37 PM
JohnnyC JohnnyC is offline
Nice! These LKs are not too light especially with a bad back like yours and mine. I think a dressed LK weights 230lbs. Can you take a close up picture of the control box components? It looks similar to mine which eventually I will be refurbing and there a some lose wires.
How is the back coming along? As for your knee replacement, how long will you be off your feet and prohibited from doing any physical work? I'm waiting for the day when they can do a brain replacement and I'll be first in line.
JohnnyC
New Jersey
Old 01-12-2018, 02:43:56 AM
Motorhead's Avatar
Default Re: Onan 2.5LK Factory Enclosed. Installed Gauges. Now like Contractors Model
The control box picture that shows the 5 amp fuse for the LEDs doesn't have any loose wires. You might be seeing the two output wires, the hot and the neutral that are connected together with screws and nuts and taped.
January 12th is one month since my back surgery and it feels good. I was actually looking forward to the back surgery because I was hurting so much, it was hard walking.
I am walking a mile now but the knee hurts bad after. The knee surgery I am not looking forward to even though in the long run it will work out. late this year or early next, the LEFT knee will get done.
The Control panel
and gauges of my
7.5JB
Old 01-12-2018, 06:47:15 AM
I hope the surgery works out. In the end you will be the bionic Motorhead.
As for the lose wires, I meant to say my LK has the lose wires and looks nasty. I wanted to use a picture of yours when I rebuild mine.
JohnnyC
New Jersey
Old 01-12-2018, 08:14:27 AM
Esteban32696 Esteban32696 is offline
NEAT .
My 2.5LK runs at almost the exact same settings as yours. It gets me through the hurricanes !
Old 01-12-2018, 02:23:48 PM
Motorhead's Avatar
JohnnyC
New Jersey
Johnny, I will take some and post it that or email them to you. The twinslan site is also back up now you might find a wire diagram that is close.
All of the wires are white inside my control panel.
The Control panel
and gauges of my
7.5JB
The Following User Says Thank You to Motorhead For This Post:
2.2 onan contractors unit blown up squidtrap Onan Generators 4 10-15-2016 04:40:13 PM
Onan Contractors Model Wheel Kit Viking66 Onan Generators 15 01-02-2016 07:57:47 AM
Garretson Natural gas mounting question on factory enclosed 7.5JB Motorhead Onan Generators 24 11-20-2015 08:08:42 PM
new to me CCK ONAN contractors model RETCPO Onan Generators 26 09-07-2015 11:52:05 AM
