Onan 15.0 RDJC Fuel Pump Leak
this thread has 6 replies and has been viewed 189 times
Old 01-12-2018, 07:58:32 AM
RRT74 RRT74 is offline
Default Onan 15.0 RDJC Fuel Pump Leak
Hello guys, I have the above gen set and it runs like a top. However, a few days ago I cranked it and runs flawlessly but I noticed a steady drip of diesel coming from the fuel pump. It does appear to be coming from the top of it. Time for a new gasket or fuel pump ? Any help is truly appreciated.
Old 01-12-2018, 08:01:22 AM
Max Thompson Max Thompson is offline
Default Re: 15.0 rdjc
If it is the OEM fuel pump, the diaphragm may have ruptured causing the leak.
Keep an eye on the oil level, it is possible for a ruptured diaphragm to allow fuel to leak into the crank case.
The Following 3 Users Say Thank You to Max Thompson For This Post:
Old 01-12-2018, 10:10:55 AM
Billy J Shafer's Avatar
Billy J Shafer Billy J Shafer is online now
Could also be a loose screw that holds the two parts together. But as Max said could be a bad diaphragm.
Old 01-12-2018, 10:47:59 AM
I have been dealing with a "loose screw" most of my life, not sure there is a way to fix it.
The Following 5 Users Say Thank You to Max Thompson For This Post:
Old 01-12-2018, 11:04:29 AM
Onan Dan's Avatar
Onan Dan Onan Dan is offline
I lost my screw a long time a go LOL anyhow my son in laws 12.0 DJC fuel pump was leaking oil at the pin on it so i went and replaced the vintage fuel pump with a modern day electric fuel pump and that took care of the issue like Billy said if that diaphragm leaks you may get fuel in your oil. I took the ole fuel pump off and made a plate and a gasket to seal the fuel pump hole in block and just hooked up the electric fuel pump and works just fine.
Fuel pump i used was an Airtex external electric fuel pump from Summit Racing ATX-E8153 Max psi 14 free flow rate 35GPH you would want to check the specs on your 15.0 rdjc to see if this would be suffient for your onan .
The Following 3 Users Say Thank You to Onan Dan For This Post:
Old 01-12-2018, 11:26:11 AM
Default Re: Onan 15.0 RDJC Fuel Pump Leak
Over my life I have run into. More than a few with loose screws. Trouble was most were the ones in charge.
The Following 6 Users Say Thank You to Billy J Shafer For This Post:
Old 01-12-2018, 02:45:41 PM
Motorhead's Avatar
"They" were by the bushel load at UPS.
RRT74, google "Vintage car fuel pump rebuilders" or something to that fact and you will find places that rebuild old fuel pumps. Being that Onan was owned by Studebaker and that the "R" models used a Studebaker water pump, did they use any Studebaker parts in the fuel pumps?
Back of 1958 5CCK
Contractors model
On trailer owned by
"Ma" Bell.
The Following User Says Thank You to Motorhead For This Post:
Onan 15.0 RDJC-4R/!4AA Fuel Pump Wessone Onan Generators 6 01-11-2018 10:56:15 PM
Onan 12.5JC-18R Fuel pump oil leak & Oil Presuure rhalle Onan Generators 4 10-14-2013 11:00:09 AM
Onan 15jc-3r/8149s ser 0569098370 fuel pump leak Kpack Onan Generators 7 10-04-2013 08:39:58 PM
Onan RDJC KW Fuel Leak showell Onan Generators 2 09-28-2013 09:24:48 AM
Onan DJC Fuel pump leak brisawyer Onan Generators 6 04-30-2011 10:08:29 PM
