Onan 4500 Watt Commerical Generator
this thread has 5 replies and has been viewed 2046 times
Old 08-30-2014, 03:06:51 PM
Rob C. Rob C. is offline
Question Onan 4500 Watt Commerical Generator
Need help!
Have a 4500 watt Onan generator on the back of a boom truck
It runs for 15 or 20 min. then shuts down
you can restart it then it does again and again.
changed fuel tanks cleaned carb, 2new fuel filters.
Old 08-30-2014, 05:27:54 PM
Onan Dan's Avatar
Onan Dan Onan Dan is offline
Default Re: onan 4500 watt commerical generator
hi Rob could you post the model and serial number of your Onan that will help the fellows out and I am sure they will get you some manuals also for the cost of your email address. could possible need a tune up plugs points condenser . thanks
Old 01-08-2018, 03:36:57 PM
Michael T Michael T is offline
The best thing I did with my Onan on the back of bucket truck is add a outboard motor gas tank up top with a primer bulb.
I was have similar problems with cutting out, replaced fuel pump, added fuel shut off near pump so it would't loose prime.
The seperate gas tank works great
Old 01-08-2018, 09:12:32 PM
Default Re: Onan 4500 Watt Commerical Generator
The OP has surely either fixed his set or beat it flat with a large hammer by now. Climbing down the #$%^ boom gets old quickly.
Old 01-08-2018, 09:22:18 PM
First thing is to find out whether its loosing spark or fuel or compresssion.
Easiest:
Get a comfortable chair to put beside the engine. Get a good book.
Get a can of ether and remove air cleaner so you can squirt into the carb.
Sit there with the book in one hand and the ether in the other.
Read book.
As soon as the engine starts to falter, "SQUIRT!".
If anything changes and/or it keeps running, then it's fuel problem.
If not, either spark or compression.
If it still dies completely, crank it immediately. If it turns over a lot faster than normal, then it's compression.
Else:
Spark.
Could be low oil, thin oil and old engine, bad Low Oil Pressure sensor.
Could be bad ignition coil condenser; even oily or barely opening points.
Here's an arm chair way to test for spark:
Get a spark tester like this:
https://www.ebay.com/i/322488659264?chn=ps
Hook it up to the spark plug closest to the chair.
Sit in the chair again, but don't read the book. You have to watch carefully to see if the sparks stop as soon as the engine starts to slow down.
I know all of this has been said before-----
Pete Stanaitis
Old 01-08-2018, 09:39:59 PM
len k len k is offline
old tread .... 2014
The Following 2 Users Say Thank You to len k For This Post:
Manual for Onan 4500 Generator wmpick Onan Generators 22 09-18-2016 09:48:19 AM
Onan Commercial 6500 Watt Generator Jhaus Onan Generators 16 06-26-2016 09:41:40 PM
Onan Commercial 4500 generator model #4.5BGDFB3050R bigjl71 Onan Generators 5 06-07-2014 04:50:03 PM
Onan 6500 watt generator Resistor help jt41484 Onan Generators 2 01-11-2010 11:36:30 PM
Onan CCK 4000 Watt Generator Conversion JKWidener Onan Generators 11 07-04-2009 10:56:24 AM
