Onan MDKD Repairs
this thread has 41 replies and has been viewed 2157 times
Old 03-01-2016, 07:12:24 AM
Viking66 Viking66 is offline
Default Onan MDKD Repairs
I had this thread going but wanted to become more specific to the Genset I have so I want to start a new one.
http://www.smokstak.com/forum/showthread.php?t=155482
I have the Injector Pump all fixed up but have a leak on the top where the fuel lines connect. I will receive both the O-rings and small Copper Washers tomorrow.
Does anyone know the torque value for them? I may have missed it in the manual.
I am also contemplating re-building the Control box since my search for one has yielded no results. Anyone ever done a project like that that can pass on some tips. I was thinking maybe an electrical box of some sort close in size.
Thanks.
As Always....This Place is Awesome!!!!
Old 03-02-2016, 07:55:50 PM
Default Re: Onan MDKD Repairs
I got the O-rings in and on. I just gave them a nice snug and now I have no leaks on top of the Injector Pump
Now I just need to figure out why the pump doesn't run when it should and why the Stop solenoid doesn't pull in and hold. Both are on the same circuit, so I just need to get a good look at it all.
The Following User Says Thank You to Viking66 For This Post:
Old 03-09-2016, 07:24:43 AM
Hi All.
Issue: Genset will run Only if I hold the fuel control open solenoid full in. The second I let it go it quits.
I have been messing with this beast more and more each day and I think the Stop Solenoid may be the culprit?????
I have been checking the circuits and continuity of the wires for the Control and even changed out one of the Relays (K14) just to test my theory that it wasn't bad. I tested the Circuit Breaker and found that it was not working, so I installed a fuse to keep that connection together for now.
I do not want to spend $40.00 or so bucks on a new Solenoid and have it not be the culprit. I can touch both the + and Aux with 12v and the Solenoid activates. When I hit the start switch the Solenoid pulls in, but releases as soon as I let go of it.
Any ideas are Greatly Appreciated!!!
Old 03-09-2016, 07:30:07 AM
Elden DuRand's Avatar
Images: 11
I'm not familiar with your generator but can tell you that the solenoid is okay if jumpering it makes it pull-in.
If the control circuits are working okay, you could have a tripped overspeed sensor, a bad temperature sensor or a bad oil pressure switch. On a lot of generators, these items are connected to the run circuit and will cause the engine to stop unnecessarily if they go bad.
The Onan experts here can tell you more.
Take care - Elden
http://www.eldensengines.com
Old 03-09-2016, 02:51:28 PM
BigBlockChev's Avatar
If you disconnect the solenoid + wire you can test it by moving the injection pump arm. With the arm in the off position the resistance between the + terminal and the - terminal will be around 1 ohm or so, when you move the lever to the on position at the very bottom of it's travel the resistance will jump to around 13 ohms indicating that the aux contacts have transferred. You may have to adjust the plunger a bit to get the aux contacts to make. If the resistance goes up to some value higher than 13 ohms or thereabouts the hold coil may not have enough power to keep the solenoid pulled in. If the solenoid checks out as above then the problem is elsewhere. Cheers Dan
It's always something simple.
If some is good and more is better then too much is just enough
The Following User Says Thank You to BigBlockChev For This Post:
Old 03-09-2016, 07:27:39 PM
Two pics...2000 words....LOL
Bad is what I am thinking????
ID:	248476   Click image for larger version
Old 03-09-2016, 09:37:54 PM
I would want to check the meter against a known resistance value if you can before condemning the solenoid. The field coil is around 12 ohms so maybe pull the rear generator cover plate disconnect one terminal of the field and check that. If your readings were offset by 3 ohms down each I would say they might be OK. What reading do you get when you touch the meter leads against each other. You should get less than an ohm if you get higher than that I would change the battery in the meter first and re check. If you can cross check with another meter like a Fluke that would be best. If you are still getting the same then it seems likely that the solenoid is weak. Cheers Dan
Old 03-09-2016, 09:53:23 PM
akirkland akirkland is offline
If I'm understanding you correctly, start solenoid pulls in during start cycle, but deenergizes when you release the start switch. wire marked A11-CB12 line must have 12 volts on it during run cycle. Hold solenoid in by hand as you have been doing and check for 12 volts on that wire as it runs. if no voltage problem is upstream.
Sorry, meant fuel solenoid pulls in during start cycle.
Wire A11 CB12 Line is attached to fuel solenoid.
The Following 2 Users Say Thank You to akirkland For This Post:
Old 03-10-2016, 06:43:42 PM
No voltage to A11 CB12
Old 03-10-2016, 08:12:34 PM
You need service manual 981-0502,it has wiring diagrams and start stop seguence explanation.
ONAN MDKD-1R 1B Manual mainship Onan Generators 8 12-16-2017 11:42:15 AM
Onan 8 MDKD Straitsman Onan Generators 9 04-22-2015 03:12:20 PM
Onan 8.0 MDKD runs but hardly any output SoCal Boater Onan Generators 13 07-11-2013 10:06:54 PM
Onan MDKD Low Voltage Parra-dise Onan Generators 29 06-11-2012 09:09:12 AM
Help! Can't start Onan 8k MDKD jeffgregory Onan Generators 10 09-17-2006 09:09:26 AM
