MOPAR Powered 30SK Set
this thread has 77 replies and has been viewed 2336 times
Old 08-08-2017, 01:37:58 PM
stretch67 stretch67 is offline
Default Re: MOPAR Powered 30SK set
They makes kits to put the Cummins engine and the Allison Tranny in a Ford or Chevy/GMC. Very expensive and time intensive as well.
Once done makes for a very nice truck.
My Dad's older Dodge was 4x4 with 6 speed manual, is newer one 2008 is same truck but Auto box. He hates the Auto Box. LOL
Old 08-08-2017, 02:29:36 PM
Originally Posted by Wayne 440 View Post
And an Allison 1000/2000 series or 6 speed Eaton transmission.
A Fuller RTO6610. Teach people how to split shift again.
  #33
Old 08-08-2017, 10:35:15 PM
Ben Cowan Ben Cowan is offline
clifford intake is the way to go if your serious! I have a 50 chev 5 window PU. got a 62 235 engine moderate cam, fenton split exhaust headers, smallest holley 4 barrell with saginaw 4 speed tranny, and a 373 rear end. pretty sweet will run 75 all day long looks good and sounds good doing it. carb is on a clifford, intake.
Luck, Ben
Old 08-08-2017, 11:18:18 PM
Troll's Avatar
Troll Troll is offline
I have the 9 speed variant, (RTO6609) I think. I know it's an OD nine speed. Took it out from behind a 478 Ford gas in a 8000 series heavy farm truck that burnt. Thought about replacing the V-10 in my 96 Dodge one ton with the mechanical 5.9 Cummins engine I have but have never got around to it.
Old 08-09-2017, 12:19:45 AM
Motorhead's Avatar
I'd have to look for the Hot Rod magazine that was for August or September 1970, the year I graduated High School. Anyhow, That issue covered the Plymouth trouble shooting contest that a buddy and I were entered into through out auto shop. We came in third. If I can find it, I will try to scan it and post it.
The cover of the magazine shows my "Back Side" with my knees on the radiator support working on the distributor of a 2bbl, 318 V8 and my buddy, Cliff Murphy pointing something to me. My neighbor next to my folks house where I was living at the time brought the magazine over to me and showed me the cover and said, "Aren't those the same Vibram soled boots you wear?" Sure as hell, it was me and Cliff!
The Control panel
and gauges of my
7.5JB
Old 08-09-2017, 12:32:37 AM
Email NOT Working
I spent years rowing Roadranger transmissions of various stripes. I would never want one in my own pickup. Too much rowing and the lack of synchros makes it too tiring.
Yes I know all the tricks of shifting from A to Z and used them at various times. But it is hard to beat a ZF 5 speed. It just goes right into whatever gear you want.
On the other hand I was the one that talked the boss into automatics in local delivery trucks. I believe that all the costs are lower except initial purchase plus it gets the work done more efficiently.
I suppose Roadrangers still have their place in highway trucks where they shift once an hour, but other than the "cool" factor, I don't see much use for them elsewhere.
The Following User Says Thank You to Birken Vogt For This Post:
  #37
Old 08-09-2017, 02:54:14 AM
Motorhead's Avatar
When I bought my first Cummins powered dodge, it was a second generation 2001.5 2wd with posi in the rear. In the Half year, of 2001, the .5 came with Disc brakes all around. Anyhow, working for UPS for about 25 years at the time I bought the truck, I was just about sick and tired of shifting stick shift package cars and the biger trucks. So I bought the 2001.5 Dodge with the 48RE automatic. I had it built up because I put bigger injectors and a bigger turbo. It was great unloaded to lightly loaded but towing out 28 ft travel trailer in hilly areas was a drag. The truck had 3.45 rear axle ratio and 3rd gear in the auto was direct and fourth was a .69 OD. I discovered that the gap between direct and OD made it a drag to tow. Either too wound up in direct and lugging in OD.
Second mistake was not getting 4wd. The engine alone weighs 1000 pounds and several times I got the front end stuck in sand and even having the posi, I couldn't get out.
So my wife and I talked, knowing that the 6.7 powered 2007.5 trucks were going to have all that diesel emission regen crap.
I did some checking around dealer stocks, mind you this was August 2007 and the 2008's were coming soon. I managed to find the truck I have now, a 2007, 5.9, 4x4, 6 speed STICK shift. My truck was built in December 20th, 2006. I also got lucky because at close to the end of the run of the 5.9 trucks, they ran out of the lower ratioed G56 trans that has a .79, 6th gear. It is too low geared on the highway. My truck got the 6.7 ratio trans with a .74 6th gear and better matches on some of the lower gears.
I bought it new for $36,000 out the door and because everyone wants the late 5.9's due to no emission equipment, I can still get $34,000- $35,000
Name:	IMG_2076 (1280x960).jpg
ID:	288248   Click image for larger version
Name:	IMG_1859 (1280x960).jpg
ID:	288249   Click image for larger version
Name:	IMG_1886 (1280x960).jpg
The Control panel
and gauges of my
7.5JB
Old 08-09-2017, 08:23:30 AM
HBSaunders HBSaunders is offline
they had forged steel crankshafts in them. my first wife had a vitamin c orange duster with the slant six and a bigger carb that held its own against many v-8's. she dusted me off 23 years ago. who says women ain't smart!
Old 08-09-2017, 09:35:34 AM
Matt L Matt L is offline
Thought I would ad a couple pics to this mopar thread.
ID:	288252   Click image for larger version
ID:	288253   Click image for larger version
Old 08-09-2017, 09:44:26 AM
Pauls12 Pauls12 is offline
http://www.hotrod.com/articles/hrdp-...-january-cover Motorhead, Hope this helps. Pauls
The Following User Says Thank You to Pauls12 For This Post:
Repair/ modification on a 30SK-18R PnishrPW Onan Generators 1 01-18-2015 06:37:48 PM
use a MOPAR electronic ignition to save the points sdowney717 Onan Generators 36 08-27-2012 02:58:25 AM
Old Gas Powered Rip saw. Erik Brinkerhoff Antique Gas Engine Discussion 0 05-13-2008 10:49:37 AM
