Onan 15.0 RDJC-4R/!4AA Fuel Pump
this thread has 6 replies and has been viewed 567 times
Old 08-15-2017, 08:10:28 AM
Wessone Wessone is offline
Default Onan 15.0 RDJC-4R/!4AA Fuel Pump
Good day all.
I have come upon a commercial 15.0RDJC-4R/!4AA, S/N J770277358. I understand it to be going on 30 years old this Oct, and basically I need to know if there is an option for the mechanical fuel pump (lift pump, not injector) as far as a replacement.
What I have, is a leaking fuel bowl. I have replaced the gaskets with cork, rubber, etc. and cannot get it to stop leaking-0ther than briefly. I am wondering if there is a fracture, or hair line crack in the cast aluminum housing, as it seems to get worse when I attempt to tighten up the glass bowl screw to stop the leak.
Unfortunately, this is a one-piece assembly, fuel bowl & lift pump, so replacing or removing the fuel bowl is not an option. The part number shows to be 149-1904. But, I cannot find one with searches.
So, is there an electric option for this situation? Where we can remove the mechanical pump, cover the opening with a blank plate?
Thoughts or suggestions are welcome.
Thank you.
Old 08-15-2017, 09:00:19 AM
Billy J Shafer's Avatar
Default Re: Rdjc
Check out Facet pumps. 5lb should do just fine. Others will be along to tell what they used.
Old 08-15-2017, 09:12:53 AM
Default Re: Rdjc
I have a oily dirty mechanical fuel pump for a diesel j series I would sell for a good price .. needs a good cleaning but does not leak..
I've had that happen often when buying a old j series that has sat to long.. has junk in the bowl and I can't just leave it alone and take it apart knowing I'll have to make another gasket.. I would take it off the machine and take the bowl off and look for hair line cracks with a magnifying glass.. could just be the bowl that's cracked at the top
Err.. I guess reading things at 6 am is to much for me
. Your saying the glass bowl is not removable?? But you replaced the gasket ?? I don't follow? can you post a picture??
Your machine was built 10 of 77..
Old 08-15-2017, 04:12:24 PM
Default Re: Rdjc
This would be my choice . This also eliminates chances of a ruptured diaphragm allowing fuel to leak into crank case and contaminate the engine oil. A small piece of 1/4" flat steel and some gasket material will seal the opening in the block.
The Following User Says Thank You to Max Thompson For This Post:
Old 08-15-2017, 07:08:49 PM
Default Re: Onan 15.0 RDJC-4R/!4AA Fuel Pump
Thank you everyone for the comments and suggestions. I will likely replace the lift pump-fuel bowl assembly with an electric as has been suggested.
I have cringed every time I have tightened up on the base screw for the glass fuel bowl, thinking surely this will be the time that I break it, but also thinking maybe a little tighter and it will stop leaking...but that hasn't happened.
So, I am thinking to quit while I am ahead, bite the bullet, and just replace it.
Thanks again for the suggestions.
Best regards to all.
Old 01-11-2018, 10:03:07 PM
Gpgacr Gpgacr is offline
Hello Wessone,
I'm interest in your issue. I have the same problem now. Did you replace your transfer pump with an electric one.
Could you share your work
Thanks in advance,
Gerardo
________________
15.0 RDJC/18R
S/N K770280739
Old 01-11-2018, 10:56:15 PM
Ben Cowan Ben Cowan is offline
I am familiar with those old glass fuel bowls, My experience has been to be very conservative with tightening. many many people over tighten them and warp the sealing surface above the glass bowl, this renders them almost useless. if moderate tension doesnt work then replace the old cork gasket. be sure to allow new gasket time to soak up fuel so it swells up to make a good seal. Luck, Ben
The Following User Says Thank You to Ben Cowan For This Post:
Onan 15 RDJC No Fuel To Injectors Max Thompson Onan Generators 13 03-15-2016 11:28:46 AM
Onan RDJC KW Fuel Leak showell Onan Generators 2 09-28-2013 09:24:48 AM
Onan 15 RDJC Transfer Pump showell Onan Generators 15 12-05-2011 09:37:49 PM
RDJC Flex Exhaust and Fuel Tubing Diameter KD5BYB Onan Generators 12 09-03-2009 08:01:34 AM
RDJC Return fuel fitting at injector pump. KD5BYB Onan Generators 16 06-05-2009 01:45:29 AM
