Onan 15JC
this thread has 62 replies and has been viewed 3393 times
Old 11-07-2017, 09:56:21 PM
Default Re: Onan 15JC
Open the wiring connection box, sometimes the put a 12 lead in as you said, I do not believe they "burried" them so IF it would happen to be a 12 wire, all 12 wires would be in the box.
However, I have no idea it they did that with magniciters.
Old 11-08-2017, 01:05:30 AM
BigBlockChev's Avatar
Iím not actually sure that magneciter sets are 12 lead . The differing voltage codes I have seen are all some variations of 4 wire single or 3 phase. Cheers Dan
It's always something simple.
The Feynman method , teach it to a kid , then you understand it.
The Following User Says Thank You to BigBlockChev For This Post:
  #23
Old 11-08-2017, 09:38:30 AM
EnginePat EnginePat is offline
So from what I have read there is a pretty slim chance it would be anything other than a 4 wire head, but one could hope
Pat
5GO 3/RA
7.5 jb's x4
6.0 DJE X 1
Old 11-08-2017, 01:58:42 PM
len k len k is online now
Got nothing to lose, only takes a minute to take screws off cover of reconnection box and look.
Think reason for using a 12 lead stator is it's generic, I think it can be wired for almost any use. Helps with production scheduling. They likely would be sitting on a shelf with long leads, available for almost any voltage code order. So if I were the engineer in charge I'ld just tell production to install it and wire the connections inside the reconnection box.
Old 11-08-2017, 06:11:19 PM
I'll pick it up over the weekend, I'll take a look then.
Pat
5GO 3/RA
7.5 jb's x4
6.0 DJE X 1
Old 11-08-2017, 08:51:43 PM
Newoldstock Newoldstock is offline
Originally Posted by EnginePat View Post
Once I fix the switch, and find gauge clear fronts for the gauges and clean it up I'll decide what to do with it. It's a good runner and propane.
I have read that somtimes onan used 6 or 12 wire heads instead of 4 wire heads and buried the extra wires. Should I look in the gen head for them?
It is possible.
It will require a light touch to open up the ends and bring all those leads out though.
I would think twice about it and I know what I am doing.....
Old 11-09-2017, 10:04:09 AM
I am looking for the mounting dimensions for the JC feet, it is sitting on a pallet now. When I go get it I would like to put it right on a frame to make it stable to move.
I found it, 11" front engine 11.5" rear engine 21" long.
Pat
5GO 3/RA
7.5 jb's x4
6.0 DJE X 1
Old 11-09-2017, 11:02:03 AM
Leon N. Leon N. is offline
BB Chev re your comment in post #22. The fact that it may be a Magneciter has nothing to do with how the stator is configured, that is 12 leads, 3 phase or single phase. The Magneciter is simply a revolving field design and produces the magnetic field which cuts across the stator windings what ever the configuration. Good comment, however.
  #29
Old 11-09-2017, 02:46:55 PM
Leon I am basing my comments on the fact that I have never seen a 12 lead magneciter gen end , though I have seen many odd voltage codes hey have all been 4 lead ends. I have never heard of anyone owning one either. I have seen many YD gen end 12 lead sets, common as can be. If you have definitive information please share with us. Perhaps Billy or one of the other oldtimers could shed some light on the issue. Cheers Dan
  #30
Old 11-09-2017, 03:51:23 PM
Leon, I have no info about this, I have read threads with no notice weather the gen was a magniciter or not. I have read threads back to 2009 about the same thing I am wondering about. They usually end without a difintive answer.
Pat
5GO 3/RA
7.5 jb's x4
6.0 DJE X 1
Onan 15JC 12.5JC Why did they do this? StarrLion Onan Generators 23 03-13-2015 04:18:33 PM
Onan 15JC ID Help Crustycritter Onan Generators 8 08-09-2013 07:19:41 AM
Onan 15JC 3CR /120/240 Onan Dan Onan Generators 10 01-25-2013 10:52:21 AM
Help me out with an Onan 15JC wilson Ross Onan Generators 21 08-29-2012 12:00:29 PM
Onan 15jc Kpack Onan Generators 10 08-17-2012 09:36:14 PM
