Genset 100kw ENBA NG to Propane Questions
this thread has 65 replies and has been viewed 2815 times
Old 12-11-2017, 12:50:11 PM
EricWood's Avatar
EricWood EricWood is offline
Default Re: Genset 100kw ENBA NG to Propane Questions
Natural gas set up is going to run a little too rich on propane, at the same settings.
Old 12-11-2017, 12:53:30 PM
reid070 reid070 is offline
If it was running on NG previously you will be richer running on propane . Be careful as richer with dry fuels can burn valves . Opposite of gasoline
Steve
The Following User Says Thank You to reid070 For This Post:
  #23
Old 12-11-2017, 03:11:22 PM
len k len k is offline
Default Re: Genset 100kw ENBA NG to propane questions.
Generally engines consume fuel proportional to kw rating, ei doubling the rating doubles the fuel consumption ( both no-load and full load).
So with a 100kw gen and only needing a 25 kw gen your about 4X oversized on the gen, that will cost you BIG TIME in extra fuel use. So much that you might save money by giving the 100kw gen away for free and buying a used gen of correct size. ( do need to be oversized a little to start big motors if you have any).
For comparison if had a 30kw gen and only needed 15kw gen then after ~ 2 weeks of cumulative run time the extra gasoline consumption of larger gen would be about the cost of a buying a used 15kw Onan gen. Run your fuel cost numbers, over sized gens only make cost sense if you hardly ever use them, but then again you will have to run them periodically to exercise them .
Old 12-12-2017, 12:06:03 AM
Jonny Hotnuts Jonny Hotnuts is offline
Let me clarify, its REALLY only just a mere 66kw at single so it will hardly use ANY fuel right?!!
-I guess this would be a bad time to suggest I was considering a turbo upgrade? I have a spare FP Billet GT3582r that would look AWESOME on this Onan!
Truth is I get that it is more generator than I need....however....the kid in me likes the fact that its ridiculous. If it was just a little to big it would be meh. The fact that it is a mountain makes me laugh. Now, I NEVER said I made good decisions.
Yeah, it will use lots of gas but IMO one can not put a price on awesomeness. LOL
~JH
Old 12-12-2017, 01:09:52 AM
Jim McIntyre's Avatar
Originally Posted by Jonny Hotnuts View Post
...Let me clarify, its REALLY only just a mere 66kw at single so it will hardly use ANY fuel right?...
I think you're being facetious, but no. Lightly loaded, it'll still inhale gas as if it were a 100 kW set, even though you'll see only 66kW of capacity.
Old 12-12-2017, 02:28:41 AM
AngrySailor AngrySailor is offline
Johnny, you and I have the same "issues" I would say
ID:	298164   Click image for larger version
ID:	298165   Click image for larger version
Old 12-12-2017, 10:55:05 AM
grif grif is offline
Seems like you'll keep enough tank pressure for liquid delivery way below zero,,, in my mind something like -30F.
Old 12-12-2017, 11:10:37 AM
Maybe one can't , but the gas company can.....
Bit like driving cross country at 8 mpg in a 1969 Camaro Z-28 with 327 , high lift cams, Holley duel pumpers, headers, chambered exhaust, class winner at the dragway, ( only got to drive it 1 weekend, car sold in 4 days). Dad was a car dealer, we keep couple 55 gal barrels of gas just to make sure we could stay in business, demo and sell the regular cars during Arab Oil Embargo of ~ 1972
Using post #7 numbers of ~ 6 GPH no-load Propane, 14 GPH full load, which sound reasonable,
I estimate your 100kw gen at 8kw load is 6.6 GPH, at 25kw load 8.
Whereas a 25kw gen at 8kw load is 2.1 , 25 kw load 3.5, big difference!!
Problem is 100kw gen no-load will use ~ 4X fuel of a 25kw gen at no-load.......no-load consumption of oversized engines is wallet killer on long runs (a day or so) . And as you apply a load fuel consumption only goes up from there. Run fuel numbers for a day or week run, costs will surprise you.
Unless your Bill Gates after some run time cost gets so bad you'll want to shut it off and sit in dark. Even with a small 7kw gen cost/KWH of electricity will be ~ 4X that of utility at BEST ( full load), maybe 8X at 1/2 load, don't want to even think what it is at 1/4 load. Your MINIMUM fuel cost will be no-load times hours you run it. For 100kw gen, a one week run 24/7 your minimum cost (no-load) would be ~ 1000 gal, if gasoline that would be ~ $2400 That's why it's awesome if someone can afford to run it.
Fuel tank $$..... ignoring vaporization ability , a given tank will only last ~ 44% as long with a 100kw vs 25 kw gen (assumes 25kw load), this 44% drops to 32 % if load is 8kw. This can become a problem during blizzards or emergencies if a truck can't get in to bring more fuel.
Old 12-12-2017, 03:12:42 PM
armandh armandh is offline
propane is a way richer fuel than NG
and YES you must adjust for it.
a generator that is 17.5 KW on gasoline
is 16 on propane 15 on NG
the different BTU density is substantial about 7% greater in your case
Old 12-12-2017, 04:59:21 PM
Looking at the rating tag, it is rated at 300 amps 120/240 3 phase. It is rated 347 amps 120/240 single phase (last box, lower right of tag). It looks like a little more than 66 KW in single phase. What am I misinterpreting here?
The Following User Says Thank You to Max Thompson For This Post:
Onan Microlite 2.5 Genset Propane Generator RMoe Onan Generators 2 01-19-2016 05:04:38 PM
A 1983 1 KW Onan genset on Propane analog man Onan Generators 3 11-15-2010 01:45:19 AM
30RZGB Gas Propane Genset Trouble Joe Batts Kohler Generators 3 09-07-2010 03:05:53 PM
Kurz & Root 100kw genset Fatboy Generators & Electric Motors General Discussion 18 12-18-2007 11:32:18 PM
HELP, Propane genset delemma Gary Koleno Onan Generators 14 11-22-2004 01:58:57 AM
