Onan Emerald Plus Genset Starter
this thread has 15 replies and has been viewed 621 times
Old 12-24-2017, 09:14:09 PM
precycled precycled is offline
Default Onan Emerald Plus Genset Starter
Hello all. The starter on my Onan Emerald Plus Genset just kicked the bucket. The starter just spins so maybe it could be fixed by replacing the plastic gear, but it might just be easier to replace the whole starter. Regardless, I am having a hard time figuring out which starter to order and was wondering if anyone could point me in the right direction. The model number is 4BGEFA26100P and the serial number is G990946531. Thanks for your help.
Old 12-24-2017, 09:26:51 PM
Billy J Shafer's Avatar
Default Re: Onan Emerald Plus Genset Starter
I believe there was an update to that starter. I will check my files.
Old 12-24-2017, 10:05:15 PM
Motorhead's Avatar
The starters have a crappy plastic drive pinion on them and they can strip out. The machine you have is a Spec "P" and the complete starter number is 191-1667.
They sell a pinion kit 191-2129 is just the gear and some various parts. The more complete pinion kit is 191-2187.
I would remove the starter first and take it apart and check the condition of brushes and commutator FIRST, then decide whether to fix just the drive or replace the complete starter.
I bought a starter as a spare for my 4BGE off of ebay. Be careful as many are China junk.
The Control panel
and gauges of my
7.5JB
Old 12-24-2017, 10:06:59 PM
Thanks for the part numbers. I am going to see what I can find out and I will report back.
Old 12-24-2017, 10:10:48 PM
Motorhead's Avatar
Do you have an hour meter on the generator?
The Control panel
and gauges of my
7.5JB
Old 12-24-2017, 10:40:06 PM
I do. The generator has 938.5 hours on it.
The Following User Says Thank You to precycled For This Post:
Old 12-24-2017, 10:44:15 PM
len k len k is offline
Starter may be corroded/froze in engine. Don't pry on starter ears or they may snap off. I heated engine aluminum casting, then broke starter free by tapping on starter ears to make it ROTATE. Came right off fine.
Also if have not run gen for few months clean slip rings before making AC to protect $$$ Ac voltage reg.
The Following 2 Users Say Thank You to len k For This Post:
Old 12-24-2017, 10:52:22 PM
I have only had the RV for a month, but it has been working fine. I have been remodeling the RV and I have been starting the generator at least a few times a week since I bought it. We were installing some new Bilstein shocks on Friday and I tried to start the generator so we could use the power to run the air wrench, and that is when the starter went out. It was doing fine before then though.
Old 12-24-2017, 11:41:51 PM
Motorhead's Avatar
As Len said, the starter can corrode (the aluminum) where it slips in to the engine housing. If you can't heat it, use some good penetrant such as Kroil or PB Blaster and spray the junction where the starter fits. Loosen the bolts and tap around the starter front flange to break it loose. The brushes are behind the rear cover. When you take the starter out, you undo the two long bolts that hold the starter together. Be careful to NOT let the starter armature slide forward as the brushes will come off of the motor commutator.
The Control panel
and gauges of my
7.5JB
Old 12-25-2017, 12:10:11 AM
Newoldstock Newoldstock is offline
Don't hit it with a hammer, magnets inside will break and then you will need a new one.
If you do break an ear off you can solder it back together with these cheap zink rods from bernzomatic and think they are great.
https://www.youtube.com/watch?v=3SBfP4_i1Go
The Following 3 Users Say Thank You to Newoldstock For This Post:
Onan Emerald 1 Genset Manual mbb111 Onan Generators 57 12-14-2017 08:41:04 PM
Onan Emerald Genset Help skydrojas Onan Generators 13 08-19-2017 10:58:53 AM
Onan Emerald 4000 BGE Starter Won't Engage & Start anemic Onan Generators 15 05-01-2016 10:33:08 PM
Onan 5k Emerald GenSet starter fix ppaul Onan Generators 16 07-03-2012 06:49:42 AM
Onan Emerald III genset Yngbld14 Onan Generators 6 08-12-2011 01:06:34 AM
