Onan 35EK Coolant Temp on Gauge Very Low
this thread has 25 replies and has been viewed 769 times
Old 01-04-2018, 12:53:06 PM
farokh farokh is offline
Default Onan 35EK Coolant Temp on Gauge Very Low
Hey gang, my 35EK (serial # A970627734, spec 86116D) has been showing very cool temps on the coolant gauge when I run it up here in NY. For example, yesterday, the gauge barely went up to 100 degrees. I replaced the thermostat a couple of years ago with a 185 degree unit, and I'm not sure if something went wrong with it, or if the gauge is just reading wrong.
First, where is the coolant temp sensor located? Is it on the engine side of the thermostat or on the radiator side? I looked in both the Ford engine parts manual and the Onan parts manual, and I can't seem to find where the coolant temp sensor is located.
Any thoughts?
Thanks and keep warm!
Old 01-04-2018, 02:01:58 PM
lokay5's Avatar
lokay5 lokay5 is offline
Default Re: 35EK coolant temp on gauge very low
The temp sensor will be on the engine side of the 'stat.
1973 CK5 Blazer
The Following User Says Thank You to lokay5 For This Post:
Old 01-04-2018, 03:02:39 PM
suntreemcanic suntreemcanic is offline
If you have a temperature gun check the block temperature at the temp sending unit. That will tell you if your engine is heating up. If you do not have a gun go to Harbor Freight and buy one for around $25. It will be the best tool investment you ever made this year. One thing they are great for is checking all your plug ins and switch boxes in your house for excessive heat created by a bad connection.
Old 01-04-2018, 04:45:50 PM
I have one and that's something I didn't think of. I just have to figure out where the temp sensor is on the motor. Hopefully it's obvious
Old 01-04-2018, 08:57:33 PM
You can feel the difference between 100 and 180 by hand. 100 is pleasingly warm, 180 will make you flinch off.
You will probably have 4 coolant temp sensors. One pre hi and one hi temp, for the lights and shutdown, screwed into the coolant jacket, they will look similar to one another. One low temp, it looks like a big alumiminum tylenol pill, one wire on it, it will just have a bolt run through it keeping it pressed onto the engine-often they use a bolt already in use. The last one looks unique, will be the sensor for the gauge.
The Following User Says Thank You to pegasuspinto For This Post:
Old 01-05-2018, 11:40:15 AM
Default Re: Onan 35EK Coolant Temp on Gauge Very Low
One small additional note on using the HF temp gun:
I used one a lot on my 30EK when I was cleaning out the cooling system, some years ago. I got really funny readings when I held it anywhere near the plug wires with the engine running. This was a bit of an issue because the manifolds are on the other side from the spark plugs and reading the manifolds won't tell you much about coolant temperature.
As previously mentioned, just test the temp with your fingers; "ouch" or "too hot to leave my hand on it" equals something over about 137° F, according to UL some years ago.
Pete Stanaitis
The Following User Says Thank You to Pete Spaco For This Post:
Old 01-05-2018, 03:00:28 PM
OK, I tried to get some temps, and took some pictures. The temp gauge shows around 125, the oil pan around 160, the oil filter around 117. I couldn't find the set of sensors that pegasuspinto mentions. 2 of the pictures are of the sensors I found. One appears to be various oil pressure related sensors, and there's only 1 for the coolant, which is connected to piping that goes to the hot-shot block heater unit (which is long dead, and I haven't bothered to replace it).
I've blocked the output of the radiator, although it's not 100% covered, but that's how I got the temp gauge to get this high. With the radiator uncovered, it doesn't even get to 100. I'm guessing that the thermostat is warped or something and is allowing some coolant past even though it's cold. One of the bad things about have a coolant recovery tank is that you can't leave the cap off to see if there's coolant flowing without winding up with coolant spilling
ID:	299817   Click image for larger version
ID:	299818   Click image for larger version
ID:	299819   Click image for larger version
Old 01-05-2018, 04:59:59 PM
yellowlister yellowlister is offline
Pull the thermostat housing off and check it.. not much else you can do. Probably stuck open
The Following 3 Users Say Thank You to yellowlister For This Post:
Old 01-06-2018, 03:37:12 PM
Gunny Gunny is offline
#1. If it used to show temperatures a lot more reasonable, then your thermostat has probably stuck open or has some trash stuck in it. Pull it out, drop it in a pan of water with a cooking thermometer, put it on the stove and see what it does and when. Do this while the wife isn't around. For some reason they get odd about us using their kitchen for this sort of thing.
#2. Some times genset manufacturers put them in the darnest places, not all of them good places.
#3. Takes them a while to get warm, especially this time of year. 10 to 15 minutes?
In the pictures you attached, one (in the Tee) is probably the hight temperature shut dow switch. The other one looks more like a pressure switch or transmitter.
If its been a couple of years, time to flush thew cooling system and replace the thermostat anyway.
The Following User Says Thank You to Gunny For This Post:
Old 01-07-2018, 02:17:21 PM
Yeah, I figured I'd just have to replace the 'stat. It's just that it's a pain to do. The coolant has to be drained and the fan has to come off, which in the tight quarters, is a pain. I'll just wait until the spring.
Old 01-07-2018, 02:34:19 PM
If you need to run it before getting a chance to do the thermostat try to keep the radiator blocked so it can run somewhat warm to help keep condensation from forming.
Old 01-07-2018, 03:03:49 PM
Motorhead's Avatar
Motorhead Motorhead is online now
Doing this test carefully... Slowly remove the radiator cap while the engine is running and insert a meat thermometer or one that reads less degrees into the filler cap and read the coolant temp with the thermometer. Check that against the gauge. The coolant gauge sender is usually in the head or as said earlier in the water neck before the thermostat so it is reading the hottest coolant temp.
Has the radiator ever been rebuilt where someone might have put a LARGER core, one more row of core?
Is there a bypass somewhere on the engine say for a block heater? That bypasses the thermostat.
I can tell you from personal experience that the Ford 6 takes a lot to over-heat. I drove Econoline vans for my job at UPS and it would be 115 degrees outside in Summer by the two Lakes in my area. There were LONG road stretches where you were running the van wide open throttle with the speedo pointing straight down past 85 mph, 10-15 miles in that weather and the temp gauge NEVER moved past center where it ran all the time.
Back of 1958 5CCK
Contractors model
On trailer owned by
"Ma" Bell.
Old 01-07-2018, 06:33:51 PM
lokay5's Avatar
The fan has to come off...to change a thermostat?
1973 CK5 Blazer
Old 01-07-2018, 09:54:00 PM
I already have the radiator blocked off, but not 100%. I'm going to run it when the outside temperature is a bit more normal and see what the coolant is running at and make adjustments as necessary.
I can't open the radiator cap at this point as I converted over to using a recovery tank. If I open it, it just overflows. I did measure the temp at the top of the radiator using an infrared thermometer, and it read around 120 degrees, but that was when it was close to 0 out.
I'm not worried about it overheating, I'm worried about it running too cold. The oil pan read around 160 degrees, which, in my opinion, isn't quite hot enough.
The Stant I bought (Stant 45358 SuperStat Thermostat) apparently has a lifetime warrantee. I ordered a new one, but maybe I'll get a spare from them for free. I'll give it a try
Old 01-07-2018, 10:09:15 PM
Birken Vogt Birken Vogt is online now
Email NOT Working
With all the cold air swirling around, I doubt the pan oil temperature is going to get warmer than that no matter what you do.
I have a thermocouple for my voltmeter that I tuck into a hose fitting or tape to something that should be as hot as the thermostat. Then I cover over it with insulation, paper towels, plastic shipping foam, whatnot. It really needs the insulation to register correctly. A point type thermometer is going to measure surface temperature and that is affected by air flow.
The Following 3 Users Say Thank You to Birken Vogt For This Post:
Old 01-09-2018, 02:55:55 PM
OK, so it's almost 40 out today here so I figured I'd play with this a bit. I took off the radiator cap and started the genset up. I watched, and there was very little coolant flow. I let it run for a bit, with a load, and the coolant started flowing, but just a little. So I went and brought out a candy thermometer I have (don't ask me why I have it, I'm never made candy in my life!), but it starts at 100 and goes up in 5 degree increments. When I stuck it in the coolant at the radiator cap, it read 175 degrees. So I unblocked the radiator and have been letting it run. The coolant at the top of the radiator is still 175 degrees and is just flowing a little bit. So, I think that the thermostat is working fine. The panel gauge still shows 125. So I looked around a bit more and I found what looks like a temp sensor on the front of the motor on the bottom of the thermostat water outlet connection. Anyone know how those sensors work? IE are they basically variable resistors that change depending on the temperature of the coolant? I can't seem to find this sensor in the parts manual for the motor that I have (194-203 CSG649ford.pdf).
Thanks for any pointers!
Old 01-09-2018, 03:41:05 PM
Motorhead's Avatar
farokh, Good test! How I have checked sending units, though you really just did, is by taking them out, plugging the hole in the engine to not lose the coolant.
I would get a hot plate and a pan of light oil so the temp can be read above boiling. You will use your candy thermometer. You power up the gauge usually by removing it and hook it up to the sensor with jumper wires.
With the gauge powered up and hooked to the sender, you immerse the "wet" side of the sending unit in the oil as you are heating it. You read the temperature on the Onan gauge against the Candy thermometer immersed in the oil. Put the bulb of the candy thermometer in the same depth of the oil at the sending unit. So now if you find a wide discrepancy between the candy thermometer and the Onan gauge, you have to try to figure out whether the sender or the gauge is erroneous.
If the gauge on your machine is a standard 2.25" round gauge then sometimes you are ahead just replacing both with a quality one like a Stewart Warner set.
If you suspect the sender, look carefully on the sending unit for ANY numbers besides an Onan part number.
Can you post a picture of your temperature gauge?
Found two temperature senders on ebay: 193-0318 https://www.ebay.com/itm/Onan-193-03...5XdVd8&vxp=mtr
193-0104: https://www.ebay.com/itm/New-Genuine...IAAOSwhlZYuMSS
Back of 1958 5CCK
Contractors model
On trailer owned by
"Ma" Bell.
Old 01-09-2018, 04:51:59 PM
Here's the gauge. It's 2.25 inches...
(I can't win. The pictures come out sideways no matter what I do )
ID:	300136   Click image for larger version
Old 01-09-2018, 05:12:44 PM
Motorhead's Avatar
I think those are Faria gauges. Don't know much about them but you could replace it with a Stewart Warner, VDO, ect because that is a standard size.
Did you by chance ground the wire from the sending unit to ground with the set running and see if it pegs all the way to hot? That tells you that you are at the right sending unit which I think 99.9% you are and also if it doesn't peg then it may tell you if the gauge is faulty or stuck internally.
Here is their website. You may be able to contact hem and get the OHMs spread that the gauge works at and check that spread on the sending unit.
http://fariabeede.com/2-pages/home.php
Looking back at the pictures of the BACK side of your gauges, is the water temp gauge the one with the circuit board on the back of it? If that is the one then you might CAREFULLY remove and CLEAN all connections and the three nuts that hold the circuit board to the back of the gauge. Billy S or Kevin would probably know if that circuit board is for OVER-TEMPERATURE shut down. A poor, loose or dirty connection to the gauge can cause bad read out.
Back of 1958 5CCK
Contractors model
On trailer owned by
"Ma" Bell.
Old 01-09-2018, 06:10:48 PM
So I took another look at the EM-EK Service manual I have. It turns out that the board on the back of the temp gauge is for the low coolant and pre-high temperature warning lamps, depending on the gauge sender output. I'll have to dig into it, but the sensor is in a really dangerous spot if the motor is running. It's right behind the fan, just above the water pump pulley, inside the cage. I'll have to see if I can find where the wire winds up and disconnect it on the far end to work on it safely.
Once I know if it's the sender or not, then I figure out what to replace.
Onan 45EM/35EK Coolant Level Switch radiotech Onan Generators 7 10-21-2017 04:35:40 AM
Temp gauge on the D-6 Johnredpwr Dozers and Crawlers 4 01-04-2016 02:45:07 AM
Onan 35EK coolant heater? farokh Onan Generators 10 11-10-2013 08:31:15 PM
Onan OT 125 Water Temp Gauge & Float Charger Issue jluciano719 Onan Generators 4 12-11-2012 09:46:45 PM
High Coolant Temp Alarm or Shutoff On MDJEWater Tem Graycenphil Onan Generators 1 10-10-2012 01:03:14 PM
