Onan 35EK Coolant Temp on Gauge Very Low
this thread has 25 replies and has been viewed 777 times
Old 01-09-2018, 08:58:01 PM
Motorhead's Avatar
Default Re: Onan 35EK Coolant Temp on Gauge Very Low
On a car, you can just turn the key ON without the engine running and test the gauge. Yeah, Definitely don't get your hands or fingers close to the fan. So with the engine OFF, disconnect the wire from the sending unit and hook a jumper wire that is long enough so that when you start the set up, you can then ground the jumper wire to a reliable ground and also see the temp gauge. That should keep you safe away from the fan and it might test the high temp alarm also. I read in the Faria troubleshooting section and it said that if the wire from the sensor is grounded and the gauge pegs all the way to the HOT side when powered up then the gauge is okay.
Again, you may be able to call them, explain what you are trying to do and they might give you the OHMs range of the sender at certain temperatures. You could then test it in the pan of heated oil with your candy thermometer and a good digital ohm meter. I emphasize checking the connections on the back of the gauge and circuit board for poor connections that could simply be your problem.
Back of 1958 5CCK
Contractors model
On trailer owned by
"Ma" Bell.
Old 01-11-2018, 03:03:16 PM
farokh farokh is offline
OK, so it turns out the connection at the sensor on the front of the engine was not great. when I was trying to test it, it moved a little, and the gauge moved up to 140 degrees. So, I just loosened and tightened the nut that holds down the cable, and it's now working again, showing 175 degrees. Once it gets warm out, I'll take it apart better and clean the connection, put some dielectric grease on it to keep it from corroding, and that should be that.
Thanks for all the pointers.
The Following 4 Users Say Thank You to farokh For This Post:
  #23
Old 01-11-2018, 05:53:26 PM
Motorhead's Avatar
A system like the temp gauge works on changing resistance. You cleaned up connections and got it back into parameters. Good to hear.
Back of 1958 5CCK
Contractors model
On trailer owned by
"Ma" Bell.
Old 01-11-2018, 06:25:35 PM
One other thing I must say is that the thermostat I got (Stant SuperStat) works really well at keeping the coolant temperature stable. When I was testing with the cap off, once up to temp, there was always just a little coolant flowing, instead of big swings from no coolant to a lot of coolant and back, like I've seen some thermostats do.
Old 01-11-2018, 07:02:51 PM
PopsGarage PopsGarage is offline
Whenever I replace a thermostat I always drill a hole to allow water flow. by doing that the entire cooling system warms up evenly. when the engine is up to temp the thermostat will be 100% open
The Following 2 Users Say Thank You to PopsGarage For This Post:
  #26
Old 01-11-2018, 11:24:44 PM
Motorhead's Avatar
Me too. It also helps to burp out any trapped air as some cooling systems won't circulate if air is trapped inside. Mercedes diesels were notorious for this.
Back of 1958 5CCK
Contractors model
On trailer owned by
"Ma" Bell.
Onan 45EM/35EK Coolant Level Switch radiotech Onan Generators 7 10-21-2017 04:35:40 AM
Temp gauge on the D-6 Johnredpwr Dozers and Crawlers 4 01-04-2016 02:45:07 AM
Onan 35EK coolant heater? farokh Onan Generators 10 11-10-2013 08:31:15 PM
Onan OT 125 Water Temp Gauge & Float Charger Issue jluciano719 Onan Generators 4 12-11-2012 09:46:45 PM
High Coolant Temp Alarm or Shutoff On MDJEWater Tem Graycenphil Onan Generators 1 10-10-2012 01:03:14 PM
