Running a Generator With No Muffler
this thread has 19 replies and has been viewed 943 times
Old 01-06-2018, 09:08:51 PM
KPack KPack is offline
Default Running a Generator With No Muffler
When testing a generator how long can you run it without a muffler or is it bad to do it ?
Old 01-06-2018, 09:15:58 PM
len k len k is offline
Default Re: Running a generator with no muffler
Till your ears bleed, or neighbors come with pitch forks. Over summer ran my JB without a muffler didn't think it was that loud , till I saw my neighbor and his wife starting hard at me from their deck..... that they had to get a variance to build closer to my property line than zoning allows.
I suspect it's not a problem, except for your ears. I suspect muffler only makes a small bit of back pressure that's pretty small compared to the high pressure in cylinder. So it shouldn't have any significant effect on exhaust flow rate , for heating exhaust valve. Think muffler only adds maybe 2 ?? psi backpressure, think cylinder pressure is 150-450 psi while burning.
The Following 2 Users Say Thank You to len k For This Post:
Old 01-06-2018, 09:40:54 PM
consolenut consolenut is offline
Well from what I know of car engines. Its not good run an engine without a muffler long term. Unless its designed too. As its possible to burn a valve. Just my opinion.
Old 01-06-2018, 09:50:17 PM
Birken Vogt Birken Vogt is online now
Email NOT Working
https://www.youtube.com/watch?v=jjPeP_Nn2B4&t=157s
The Following User Says Thank You to Birken Vogt For This Post:
Old 01-06-2018, 10:09:18 PM
AngrySailor AngrySailor is online now
It's not so much the lack of muffler that causes valve issues, it's the length of the exhaust opening away from the valve... if you remove a muffler and run with just the short port, air reversion can cool a hot exhaust valve causing thermal shock, if you add a short length of pipe to prevent this reversion you should be fine.
The Following 4 Users Say Thank You to AngrySailor For This Post:
Old 01-06-2018, 10:55:08 PM
What Len said.
Old 01-06-2018, 10:59:43 PM
Gunny Gunny is offline
No issues. I've run a lot of them on load banks for up to 24 hours with no mufflers (silencer) at 100% load. A Cat 3516 had an orange flame about 2' standing out of the flower pot at night.
The engine may run a little more efficiently with a littl eback pressure on the exhaust, depends on the cam profile. Have run motorcycle engines with no exhaust at all, right out of the head, never burned or warped a valve. Made some ears hurt.
The Following 3 Users Say Thank You to Gunny For This Post:
Old 01-07-2018, 07:58:39 AM
lokay5's Avatar
lokay5 lokay5 is offline
Just an old urban myth.
An engine would be more likely to "burn" a valve with a muffler.
"...air reversion can cool a hot exhaust valve causing thermal shock"
Urban myth
1973 CK5 Blazer
The Following User Says Thank You to lokay5 For This Post:
Old 01-07-2018, 08:25:32 AM
Handyhiker1 Handyhiker1 is offline
Default Re: Running a Generator With No Muffler
On a constant speed engine it is not going to hurt anything. When the RPM drops suddenly that is when the possibility to suck cold air back into the exhaust and damage the hot exhaust valve.
Old 01-07-2018, 09:47:28 AM
BRae's Avatar
BRae BRae is offline
The engines efficiency may change some however, I doubt it will damage anything but your ears.
The Following 2 Users Say Thank You to BRae For This Post:
18hp briggs vangaurd powered Generator running on propane running rich. bugman53 Generac Generators (SEARS, etc.) 1 02-16-2016 02:48:38 PM
Muffler for Generac NP-66G M/N 09600-2 RV generator timrauch Generac Generators (SEARS, etc.) 3 12-03-2014 04:04:03 PM
Better muffler for Kubota D905 powered generator Joe Romas Generators & Electric Motors General Discussion 8 05-17-2012 10:01:28 AM
Detect generator running? Isaac-1 Generators & Electric Motors General Discussion 6 12-21-2010 05:58:24 PM
Onan stock muffler 155-1258 or cheap Car muffler(s) HondaBob Onan Generators 2 01-21-2010 08:03:48 PM
