Protection of Downstream Loads
this thread has 17 replies and has been viewed 1037 times
Old 01-11-2018, 01:11:25 PM
motion motion is offline
Default Protection of Downstream Loads
I have a Onan 20.ES and it runs well, I'm curious as to what other members do to protect the loads in the event of over/under current, engine failure, fuel loss, etc. With all of the sensitive electronics in todays stoves, flat screens, A/C, etc. I'm somewhat concerned. Thanks
Old 01-11-2018, 02:07:02 PM
Augie1 Augie1 is offline
Default Re: Protection of Downstream Loads
Most will just let the branch circuit breakers protect the circuit from shorts and overloads. In this area I have never seen over/under voltage protection. I suppose it could be done if you wanted to spend the money. Plug a voltmeter in both lines and monitor it seems to work good. I have volt and amp meters connected ahead of the transfer switch so I know what the generator is putting out before I transfer power to the gen.
Old 01-11-2018, 02:16:57 PM
Ifix71 Ifix71 is offline
I use a computer UPS on my DVR and flat screen , that way it don't
Reboot every Time the lights flicker or you switch power sources.
I did notice during Irma that it don't like a frequency above 61 hertz!
John
Old 01-11-2018, 03:06:51 PM
I was thinking about the times you may not be standing near the generator i.e. sleeping or away and something goes wrong. I thought about a shunt trip breaker in conjunction with a over/under voltage, phase loss module. but I'd still need power to trip the breaker.
Old 01-11-2018, 03:21:43 PM
Leon N. Leon N. is online now
Good question! I think if you have a quality product, that is, a generator which is properly maintained you should have little to worry about.
In my situation, I employ a 1960's designed Onan 7500 watt magneciter JB generator. I was concerned like you about under voltage and more importantly under frequency operation and how this would affect not only connected appliances but the generator itself during under frequency operation as would occur should the generator wind down under load.
So without modifying the genuine Onan designed JB, I designed a separate shunt trip circuit which monitors the generator frequency and automatically disconnect the down stream loads should the frequency go low or high.
I never got around to modifying the shunt trip to not only disconnect the downstream loads but also shut down the plant seeing the generator voltage regulator is susceptible to damage should prolong operation occur at a reduced frequency/RPM.
Today, after some 45+ years of reliable JB operation, I have great confidence in the reliability of my unit that I am not in a hurry to modify my shunt trip to not only disconnect the downstream load but also shut down the plant.
If interested I can send you some information on my simple but reliable black box shunt trip design.
Old 01-11-2018, 04:57:31 PM
I don't think you need to go to that extent of protection, unless you've got a lot of expensive equipment to protect. Since you mentioned phase loss, is your genset configured for 3 phase output?
If your generator is supplying whole house power for 120/240V, single phase operation, a good surge protector on your distribution panel should adequately protect the loads from severe overvoltage and spikes. Should you decide to incorporate a shunt trip system, you can get shunt trip breakers that have 12 VDC coils. Thus, you can use battery voltage to operate the shunt trip mechanism. There are other options available for circuit breakers, such as auxiliary contacts. You could wire this into the generator run circuit to stop the engine if the shunt trip activates.
Old 01-11-2018, 06:31:07 PM
I have a UPS on my DSL modem, but that is merely for convenience - so I don't have to wait for DSL to resync after a power failure. Other than that, I figure that if some device I have is too "sensitive" to accept power from the RDJC, I should be getting rid of said device anyway.
The Following 4 Users Say Thank You to Wayne 440 For This Post:
Old 01-11-2018, 08:38:07 PM
dracer dracer is offline
I have a ups on my computer and modem and the wif , I think the wireless phone is on it also , we used to have a lot of power outs that where on and offs but when the ranger changed and the new one let the power company trim the the trees that was cured
Old 01-11-2018, 08:50:24 PM
Jim McIntyre's Avatar
I think that what you describe, possibly with the addition of an under/over frequency trip could be of some use in preventing damage to some loads under unusual generator operation. Whether it's actually worth the cost, bother, lower system reliability, and inevitable nuisance trips is a question only you can answer. For me, the answer is 'no'.
Old 01-11-2018, 10:26:37 PM
Keep in mind that a lot of the new electronics (computers, tv's, cable boxes and so on) use a switching power supply that rectifies ac to dc. These will work fine from around 80 volts @~40hZ and up to 250V @100+ hZ. If the power drops off or goes low from your gen these things will just stop making enough dc to power the device. I don't know however if they have any over voltage protection.
Low PF loads on Onan CCK and NHD Magnetite Onan Generators 3 06-15-2012 05:48:00 AM
RUSSELL Horsepowers at various loads Gary K Steam Stationary Engines, Traction Engines, Steam Boats 0 01-05-2012 12:56:29 PM
Loads & Loads of Engines Doug Waggonner Oil Field Engines & Related Equipment 26 12-14-2011 10:13:46 PM
Wisconsin TJD Loads up budro Wisconsin Engines 2 10-20-2010 04:39:39 PM
balancing loads John T Generators & Electric Motors General Discussion 10 09-13-2004 08:14:51 PM
