Onan Magniciter Theory FAQ
this thread has 80 replies and has been viewed 57616 times
Old 07-24-2013, 11:49:49 PM
Default Re: Onan Magniciter Theory FAQ
That won't work like you wish. Only way to get that kind of change in voltage is to reconnect the stator windings (if possible).
Old 07-25-2013, 01:49:56 PM
Beavisz Beavisz is offline
Talking Onan Magniciter Theory FAQ
Originally Posted by Generactech View Post
I have several magniciter onan gens in my stash of older units. I have been searching for a simple way of being able to convert these 480 volt units to a more usable 120/240 unit.
Buy a Transformer.... They are not that expensive.....
Old 11-15-2013, 04:12:09 PM
Ted_Cool Ted_Cool is offline
Here's another good Magnetic Amplifier link:
http://www.rfcafe.com/references/pop...lectronics.htm
The Following 2 Users Say Thank You to Ted_Cool For This Post:
  #44
Old 11-15-2013, 04:34:12 PM
grif grif is online now
Thanks Ted. I'll go try to digest this FAQ before pestering anybody (for a while ;-) )
I'd totally forgotten about this FAQ. I got here from around the barn,,, on the other side of which is a circulator and an isolator. I'll undoubtly get back to that well before this whole rabbit trail has been explored.
Old 03-24-2014, 05:28:02 PM
Leon N. Leon N. is online now
The attached picture is from the inside cover of the control box on a JB plant employing the Magneciter design.
Note, T2 is not internally grounded to the generator head. I took another look at my Onan JB operators manual and they very specifically say to use a bolt through the control box to connect the grounded generator lead and load wire.
In my JB, which is single phase 4 -wire, T1-T4, there is a ground stud inside the stator outlet box where the four stator leads are connected to the outside world. T2 is tied to the generator chassis at this point and this also happens to be the neutral wire in the 120/240 volt arrangement.
Since the Magneciter contains a diode bridge across the 120 volt AC terminals, I believe Onan does not want undue electrical stress put on these diodes by a floating or employing a external grounding system, at least relative to the generator frame.
Old 05-07-2014, 05:37:36 PM
The static exciter is flashed with 12 volts ONLY while the starter is energized.
Looking at the Magneciter schematic for my JB, dwg # 625A631, page 75 of 967-500, you will note the Exciter is powered by 120 VAC at E1 & E2. E1 is connected to the generator power output lead T1 and E2 is connected to T2. The 12 volt flashing circuit, terminal 35 flows through a diode, the dc field, a couple of other components and ends up at the "low" side, E2 of the 120 VAC which is the T2 power lead. Onan requires T2 to be attached to the generator frame in order to provide a completed 12 VDC path for the flashing circuit. It happens that in the single phase 120/240 output lead arrangement, this means the neutral (T2 & T3) should be connected to the generator frame.
Therefore, one can conclude, if the 120VAC neutral (T2) is not connected to the generator frame, there will be no clear (complete) dc circuit for the field flashing to take place. Now that may be why Onan says, the exciter will be damaged if the neutral, as described here is not tied to the frame. Just look at the schematic portion of 625A631 or 611C853, rev D. The diode bridge shown on 625C631 would be damaged!
Interestingly, Onan made a change to the Magneciter auto field flashing circuit in 1968 by adding a 15 ohm, 10 watt resistor in series with the 12 vdc tap off the starter side of the start solenoid in the control box. See the Onan schematic 611C853 Revision D. Perhaps this was done to protect the diode bridge should T2 not be tied to the frame.
Also, as a side note, the 7.5 Kw Onan Magneciter powers the static exciter from 120 VAC as noted above. The Onan performance specification for the exciter indicates it draws 400 watts, which put an asymmetrical internal load on one side of the stator 120 volt windings.
The Following 2 Users Say Thank You to Leon N. For This Post:
  #47
Old 12-10-2014, 06:46:00 PM
In reviewing this thread I think it is important to note especially to those engine mechanics who may want to run (spin) the Magneciter at idle or some RPM well below 1800 that by doing so for any length of time could severely damage the saturable reactor coils and thus let out the so called magic smoke.
The reason being that the Magneciter field winding and saturable reactors inductive reactance/impedance will be lowered in direct proportion to the speed reduction and this in turn can increase the AC current flowing through the coils and may over heat them. The AC inductive reactance of these coils is determined by the formula 2 x 3.14 x F x L. The inductive reactance along with any series resistance controls the amount of current that flow for a particular applied voltage.
  #48
Old 12-12-2015, 06:13:00 PM
Newoldstock Newoldstock is offline
Magic smoke:
It gets so old after a while.
In the golden age of four quadrant control we used devices called Amplidynes and mag amps to convert small control signals to larger power values.
All this stuff goes back to big gun turrets used on ships and the later was highly refined and used in the direction and stability controls of rockets of the 1940s.
I wanted to add a video off magnetic amplification to this thread so the novice could get a feel pf both how simple and yet clever this technology was.
It totally obsolete now, but I am one of the last flame holders and I repair and tune the last of them in my industry.
When they are gone I will not likely be working anymore myself.
I miss what is already been sent to the scrap heap because these machines made noises and smells well before real harm was done and I could generally have them back up and running before any significant loss in productions.
They were in mines and steel plants, ships locomotives and machines of all kinds large and small.
Like the Onan system they are barely understood today and abused and cursed by service people who do not grasp the concepts.
And this is not taught anymore to technicians or electricians...
https://www.youtube.com/watch?v=DBX1-POuJMw
The Following 7 Users Say Thank You to Newoldstock For This Post:
  #49
Old 12-13-2015, 02:07:43 AM
Vanman Vanman is offline
Diesel electric locomotives, (prior to electronic governors), controlled the load on the engine at any given throttle setting, and across the speed range of the locomotive, by sensing the control output of the hydraulic governor (ie the position of the fuel rack, on EMDs at least) and adjusting exciting current on the traction generator accordingly.
I had always wondered how this was accomplished prior to solid state electronics. I just couldn't believe that they had vacuuum tubes in such an environment! Now I have no doubt that a magnetic amplifier was the heart of the system. Beautiful
They also switched the traction motors from various combinations of series and parallel based on road speed in order to reduce the voltage / current range necessary from the generator. That system was probably comparatively simple. I don't recall that the transition speeds were different for different throttle settings. I recall it was 25 and 45 mph while increasing speed and around 40 and 20 while losing speed.
Keith
Old 12-13-2015, 03:52:32 PM
There are so many machines out there that get no attention but were instrumental in making the work place safe and reliable.
Before the mag amps and early electronics there were completely mechanical systems that did the task of backing up the human operator.
This is the Lilly C that prevented many accidents in hoisting equipment.
It was these types of purely mechanical systems that things like Mag amps and later solid state electronics replaced.
There are still some out there quietly doing the same task they were designed for 100 years ago.
Never seen one at any sort of engine show or machinery rally and this is too bad.
25kW Onan 3 phase 208 W/Magniciter Ford 6 mrmuzic Onan Generators 57 06-17-2012 11:43:06 PM
Onan YD vs Magniciter GHanners Onan Generators 14 05-20-2012 06:48:39 PM
Onan 30EK UR, Magniciter 07SX1N1C high voltage franciscanfriars Onan Generators 35 09-22-2011 08:01:59 AM
Theory of low compression on Onan CCKs c east Onan Generators 10 04-14-2011 05:27:55 PM
