IH Famous flywheel question.
this thread has 4 replies and has been viewed 1886 times
Old 01-13-2007, 02:55:59 AM
Inter Bloke Inter Bloke is offline
Default IH Famous flywheel question.
I have several famous style Inters but one, a 1916 4 HP has a different style flywheel to the rest, with square pockets cast into the inside of the outer rim of the flywheel, with it looks like plaster in them. I had always assumed this was something to do with the engines balance and that these probibally had some form of weight incorporated in them, but I have a friend who also has one of these engines equiped with this style of flywheels and he is adament that they are electrical flywheels used when the engine was set up driving a generator. The electrical flywheels I have seen on other engines were all very heavy compared to the standard wheels while these seem to be about the same size and weight as the other "standard" wheel, so does anyone know the signifigance of these different wheels.
Graham
Old 01-13-2007, 10:19:07 AM
Harry Eisenhauer III Harry Eisenhauer III is offline
Default Re: IH Famous flywheel question.
inter bloke
i am quite sure the pockets in the flywheel were for balance. i have a six horse famous with this type of flywheel and some of the pockets are filled with lead. if the flywheel were used for some type of armature any type fields would be on the outside rim and not made of lead.
harry eisenhauer
Old 01-13-2007, 06:08:17 PM
Those FWs with the pockets are usaully on the throttle gov/ titan engines. I don't think IHC ever made any Fws extra heavy for generater service. or at least none that I have seen in the parts books.Rob
Old 01-13-2007, 10:37:18 PM
Thanks bloke's,
The engines I have seen with these were all throttle governed so I surpose thats right , the ID plate is missing on the one I found so it may be a "Titan", I called it "Famous" style because its much the same construction as my Famous and the "Victor". I am not sure about my mates engine, I will have to look. Harry what year was yours made ? I am just wondering if it is something they did to later models and not to the earlyer ones.
Thanks anyway fellers,
Graha
Old 01-14-2007, 03:37:23 PM
Al Wait Al Wait is offline
I once had a 1914 6 HP t/g Titan with the pockets in the flywheels. They were filled with lead for balancing. Al Wait
International Famous flywheel run out Dan thompson Hit & Miss Gas Engine Discussion 3 03-22-2017 01:16:51 AM
Ihc Famous Flywheel Ray Cardoza Hit & Miss Gas Engine Discussion 0 03-06-2014 01:09:27 AM
IHC Famous Flywheel Weights jboyer1028 Hit & Miss Gas Engine Discussion 2 10-14-2012 05:51:47 PM
Removing a 2hp IHC Famous flywheel Johnny T Hit & Miss Gas Engine Discussion 6 02-05-2008 08:05:50 PM
1 HP Famous flywheel color? RBrigham Hit & Miss Gas Engine Discussion 2 12-30-2006 08:00:06 PM
