Flywheel Question
this thread has 2 replies and has been viewed 1348 times
Old 09-01-2002, 02:31:34 PM
Bill Sommers
Default Flywheel Question
I have 4hp Fairbanks-Morse T. One flywheel was previously repaired and welded. I want to replace it as it vibrates and shakes the engine. I got a set of Flywheels off a Z but the shaft size is 1/4" larger than the T. What can I do to get it to fit?
Old 09-01-2002, 05:40:32 PM
RICHARD L. BROWN
Default Re: Flywheel Question
FIND A SET OF 4HP. MODEL H FAIRBANKS FLYWHEELS . THE H AND T FLYWHEELS WILL INTERCHANGE
Old 09-01-2002, 07:01:32 PM
MZ
Bill, have a machine shop (or somebody you may know with a metal lathe) build you a couple bushings with an I.D. the same diameter as the shaft on the "T" and an O.D. the inside diameter of the "Z" flywheels. Depending on how the flywheels are keyed or fixed, you may have to cut a slot in the bushings for say a gib key if that's what is used. Be sure the bushings are a minimum of the same width as the hubs on the "Z" flywheels. I think you have the right idea to get the "repaired" flywheel off of there before something regretable happens. Good luck.
Upright with mag flywheel hub question joder Maytag Engines and Collectibles 0 02-04-2019 01:58:16 AM
TJD Flywheel Question Saukengines Wisconsin Engines 3 11-02-2012 07:55:50 PM
Flywheel question allgattill Maytag Engines and Collectibles 2 06-01-2011 07:33:22 AM
Flywheel question Alan R Hit & Miss Gas Engine Discussion 8 02-20-2007 03:51:24 PM
flywheel question Ray Cardoza Hit & Miss Gas Engine Discussion 1 03-01-2006 09:50:50 PM
