SEGPRSM-generator
this thread has 3 replies and has been viewed 1163 times
Old 11-24-2015, 04:50:10 PM
catienlla catienlla is offline
Default SEGPRSM-generator
New to this forum. Please excuse any mistakes or no-nos I am guilty of. Thanks Came across a military portable machine shop, mounted on a trailer with fold out sides. It contains a generator and welder powered by what looks like a D198 White diesel. Found a similar looking unit but not much info on the web it was listed as Shop Equipment General Purpose Repair Semi-Trailer Mounted thus SEGPRSM. It contained a mep-803 powered by an Onan. All the tags are faded, does anyone know what the generator is? Engine runs but no power output. Could be a switch needs closed but I don't know. Any help would be great. Thanks again, Mike
Old 11-25-2015, 05:49:26 PM
dependable dependable is offline
Default Re: SEGPRSM-generator
If I understand the question, the first one might be a MEP-004(15 KW). Some pictures would help. The 803 is a fairly current 10 KW unit. I think some of those trailers had MEP-003s, but they would not look like a White diesel.
Old 11-25-2015, 07:03:06 PM
Found a unit that was sold in Ga. with a White diesel but it didn't list what the generator was. NSN 4940-01-006-3229. It looks like the one I have. Controls for generator and welder are in a panel in the trailer front. Unit contained a lathe, mill, drill press and air compressor, all of this is gone. Also most of the small tooling is gone. There is paperwork for some of the tool kits but nothing for the generator or welder. Would like to identify generator and search for a manual or someone with the knowledge to make the gen. work. I don't think there is much wrong maybe a switch not closing a contact.
Old 11-27-2015, 03:42:19 PM
Identified this unit, it is a SEGPRSMD, NSN 4940-01-006-3229. The generator is a 12kw Dynamotor model SMD300 powered by a D298 White. Manual is a TM-9-4950-549-14-P. Has to have control circuit breaker on, power selector switch in generator position and push and release Dynamotor start-stop switch to make AC power. Maybe this will help someone later on.
The Following User Says Thank You to catienlla For This Post:
Generator Generator (sears)No electral output BobbbyL Generac Generators (SEARS, etc.) 17 03-26-2015 05:25:57 PM
Onan Fairbanks Morse v45s-20 generator light plant my first vintage generator DaveinRI Onan Generators 32 06-19-2014 03:19:24 AM
Ford Generator? generator-starter? TekNik The Junque Drawer 5 04-09-2014 09:10:01 PM
Generator Project 1920 Dodge 4 Cyl. Side Valve and Western Electric Generator jeffery flynn Antique Gas Engine Discussion 7 05-27-2010 02:43:27 PM
Sears companion 5000 watt generator needs generator unit daytonakid Generac Generators (SEARS, etc.) 1 05-17-2010 04:21:46 PM
