It's a thumper...
this thread has 13 replies and has been viewed 3714 times
Old 04-19-2009, 10:19:43 PM
Patrick62 Patrick62 is offline
Default A completed project
I will remember to grab a camera and get pix tomorrow.
Paint job is done, 220V outlet installed, and it was ready to assume the position of honor out there feeding my workshop. I can move it with the hand truck, barely.
This thing is incredible! I turned on all the lights, and exhaust fan. Then I turned on the air compressor. That put the load up a bit. turned off the exhaust fan, and played with a welder... It struggled, but did not give up easy.
Way, way past 3000 watts.
-Pat
Old 04-22-2009, 01:19:48 PM
Default oops
It tried to self destruct last night.
I started it up and was fiddling around in the shop while it warmed up.
Vroom! What the ....
When I got out there it was running about 7000 rpm! The linkage had fallen off the governor! I replaced the missing/broken cotter pin with a new one. All is as it should be. It survived! I am amazed.
-Pat
Old 04-22-2009, 08:02:06 PM
BTPost's Avatar
BTPost BTPost is offline
Images: 1
Talking Re: It's a thumper...
You have heard of the preverbial "Brick Sh*T House... That is what these are built like.....
Bruce in alaska
Old 12-07-2015, 01:23:59 PM
restore49 restore49 is offline
Default Re: It's a thumper...
Now there are 3 people with one - will check back when in hand. Bob
