MEP 003A no power engine starts and runs good.
this thread has 8 replies and has been viewed 1069 times
Old 11-22-2015, 01:10:43 PM
Ed ke6bnl Ed ke6bnl is offline
Default MEP 003A no power engine starts and runs good.
I was given a MEP 003A 10kw generator, was told it was in good working order. The motor started right up. BUT I get no voltage out of any of the leads.
Any clues to where I can start to check it out any reset button I missed thanks for the help
Name:	10kw gen 5.jpg
ID:	239360   Click image for larger version
Name:	10kw gen 3.jpg
ID:	239361   Click image for larger version
Name:	10kw gen 2.jpg
Old 11-22-2015, 01:16:44 PM
Triple Jim Triple Jim is offline
Default Re: MEP 003A no power engine starts and runs good.
It could be one or more of many things. Do you have copies of the manuals yet? There is a good troubleshooting section in TM5-6115-585-34.pdf that should help you narrow down the problem.
Old 11-22-2015, 01:41:31 PM
dependable dependable is offline
As Jim stated, the manuals are useful. They can be downloaded fro free at www.liberatedmanuals.com.
Are your AC & DC circuit breakers on? A few more steps on these than most consumer models, it is worth going over the operator's manual on these too.
TM-5-6115-585-12 is operators manual.
Old 11-22-2015, 05:39:25 PM
Richard L Richard L is offline
Are you holding the start switch clear to the right when starting the set,and then leaving it there and see if you build up voltage.
These sets need to be flashed on start as there is enough residual magnetism to excite the fields.
Also DO NOT CHANGE THE VOLTAGE SELECTOR WHEN SET IS RUNNING.
R
Old 11-22-2015, 05:46:11 PM
R
I will need to get a couple of batteries to start it, it has been a while, and I downloaded the manual. I will try what you say. I believe it is something simple because it was suppose to be in good working order when it was given to me.
Old 12-19-2015, 08:20:29 PM
Have to say it did not start this time, maybe not good enough batteries get a click, do not see the plunger on the end of the solenoid moving, drawing 45 amps when putting in start mode. Terminal on the housing seems loose as well as the one on the starter solenoid. Might have to pull the starter and check that next. That the news for the present time
Old 12-21-2015, 01:46:47 AM
Robert Irvin Robert Irvin is offline
Make certain (check manual) that your batteries are connected correctly. If you just added batteries and are unfamiliar with the generator, it is easy to hook up to incorrect terminals and unit will not start but click only.
Old 12-21-2015, 09:49:27 AM
I finally broke out the manual and I first hooked them up wrong, I now clearly marked the polarity. How hard is it to pull the starter?? terminals are loose and I would like to bench test it.
Old 12-21-2015, 04:44:13 PM
No harder than an old truck, and you don't even have to crawl under it.
Another thing to remember is never disconnect batteries when unit is running, you can damage the charging system.
stover ka runs then dies then starts right back up ? PugHmaN Antique Gas Engine Discussion 5 06-19-2015 02:36:46 PM
Onan TGHAA starts but runs rough sparksatwindsor Onan Generators 16 11-24-2013 03:53:16 PM
Kohler runs and starts very well or not armandh Kohler Generators 3 10-15-2011 08:57:54 AM
Onan 4.0cck Starts, runs then quits Kevin P Onan Generators 10 09-21-2006 12:28:50 AM
Ignition good, engine runs bad Mac Leod Antique Engine Archives 8 05-10-2004 04:58:18 AM
