need help please simple question
this thread has 5 replies and has been viewed 996 times
Old 12-28-2015, 03:46:36 PM
MEPman MEPman is offline
Default need help please simple question
We had an ice storm and will be without power for a few weeks. my question is on an MEP 002A the label says to get 240 single phase to connect L1 and L3 and L0 lugs. I know the L1 and L3 are both 110 for each leg of the 220,but what do i do with the L0 lug?
Old 12-28-2015, 06:24:27 PM
len k len k is online now
Default Re: need help please simple question
I don't know your gen, but I suspect L0 is the neutral (and the safty ground if you have neutral and frame bonded).
The military gen experts will be along shortly.
Old 12-28-2015, 07:44:19 PM
cuad4u cuad4u is offline
When the reconnect switch is in the 120/240 single phase position (3 o'clock) you get.....
L3-L1 = 240V
L3-L0 = 120V
L1-L0 = 120V
Did this answer your question.
The Following User Says Thank You to cuad4u For This Post:
Old 12-28-2015, 09:08:02 PM
I think so. i connected L1 and L3 to get 220 into the house and connected L0 as the neutral. did i do this correct?
Old 12-28-2015, 09:55:25 PM
Triple Jim Triple Jim is offline
Yes, that will power all your 240v and 120v loads correctly. The frame of the generator should be connected to your panel's earth ground too.
The Following User Says Thank You to Triple Jim For This Post:
Old 12-28-2015, 10:03:48 PM
Thanks all. this is the first time i have used the MEP 002a for anything constant in a long time. i have always used an Onan DJB before.
hello, new user with a simple question. tjc transport Onan Generators 13 04-28-2015 08:23:43 PM
simple question...duplex pump nomenclature TractionEngines Steam Stationary Engines, Traction Engines, Steam Boats 3 03-11-2014 09:04:42 PM
simple ZC 118 timing question John Drabik Antique Gas Engine Discussion 3 04-30-2012 04:59:35 PM
Simple Question about Exhaust Moisture? superduty Onan Generators 4 04-25-2011 06:01:42 AM
Simple question, maybe a simple answer? Jaeger Don C. Wiley Antique Engine Archives 6 04-05-2004 11:00:08 AM
