MEP 002A weak circuit breaker?
this thread has 1 replies and has been viewed 795 times
Old 01-09-2016, 01:08:40 PM
titanicbull titanicbull is offline
Default MEP 002A weak circuit breaker?
Having a problem with my MEP 002, when I turn on my 15amp grinder the voltage spike immediately throws the main breaker with no other load present. Could the 30 yr. old breaker just be "tired"? Thanks/ Ed
Old 01-11-2016, 04:36:12 PM
cuad4u cuad4u is offline
Default Re: MEP 002A weak circuit breaker?
Are you sure you described the problem correctly? Assuming you plugged your 15A grinder into the "convenience outlet", I do not think the main circuit breaker is in the circuit. As I remember the "convenience outlet" has a separate circuit breaker.
Any way your 15A grinder probably draws 2/3 times that amperage on start up. That may be the reason your breaker is tripping.
I have a 30year old Skill all metal 9 inch grinder which the data plate states 15A. My 002A will start and run it all day without any problems.
6 hp ihc circuit breaker Scott Kocher Antique Gas Engine Discussion 9 09-03-2014 08:07:36 PM
Mep 002a 28v charging circuit inoperative cuad4u Military MEP and Aircraft Gen-Sets 9 12-22-2013 08:23:31 PM
Need MEP-002A main breaker robtay Military MEP and Aircraft Gen-Sets 2 11-05-2011 11:02:05 AM
Breaker, breaker! (circuit breakers) Nubian Onan Generators 5 02-12-2008 08:34:56 AM
need circuit breaker Dale Lauborough Kohler Generators 8 03-22-2007 10:10:10 AM
