Just a curious question, Rotor/Stator
this thread has 10 replies and has been viewed 441 times
Old 11-21-2017, 01:28:47 AM
nothingbutdarts nothingbutdarts is online now
Default Just a curious question, Rotor/Stator
Today I pulled the rotor and stator off an extended stack 15.0, 12 wire JC.
I'm not getting any younger in life, both were a tad heavy. I beleive they also make a 17KW RJC. The JC units have the taper shaft crank and rotor is held on with the thru bolt.
My question is on the bigger units like the 20, 30 and 40KW units, like on a 20KW Onan, how is the rotor connected to the engine? Taper shaft or bolted to a flex plate like maybe like the SK I have.
On the bigger units, how does one get the stator off the rotor? Can a guy lift a 20KW stator or rotor?
I just ask out of curiosity, as there are quite a few here who do or did this for a living and I wasn't sure how you got the bigger "medium sets" apart for repairs.
As usual Thank You!
Old 11-21-2017, 02:12:00 AM
Email NOT Working
Default Re: Just a curious question, Rotor/Stator
Larger units have a kind of flex plate that fits into a precisely machined well in the engine flywheel and a bunch of bolts.
They are standard SAE sizes.
You take off the finger/bug guard screen thingy and undo all the flex plate bolts.
Then you support the whole generator with a fork lift.
Then you unbolt all the bolts between the generator stator/housing and the engine bell housing and drive the fork lift away with the generator on it.
The Following User Says Thank You to Birken Vogt For This Post:
Old 11-21-2017, 09:16:41 AM
Billy J Shafer's Avatar
Plus you have a good supply of band aids on hand.
Old 11-21-2017, 09:40:18 AM
Jack Hottel Jack Hottel is offline
The manual on my 25 KW states, "The rotor weighs over 100 pounds, so use care when sliding it in the stator." Very good advice!
Jack Hottel
Old 11-21-2017, 09:50:45 AM
Troll Troll is offline
Jack Hottel
With anything larger than about 10hp I slide 1/16" phenolic plastic strips between the rotor and the stator after pulling the end bell or access panels from the motor/generator to preclude damaging either.
The Following 3 Users Say Thank You to Troll For This Post:
Old 11-21-2017, 12:57:07 PM
len k len k is offline
1/16" phenolic plastic strips ........WOW didn't know the magnetic gap was that large. But that gap sounds reasonable for tolerance buildup reasons.
Old 11-21-2017, 01:01:52 PM
I have several boxes of differing sizes of these strips which are insulators for differing purposes. I used that as example as they fit most applications. I've never had an Onan generator apart but several antique Hobart welders and such and 1/16" is the most common strip to use. Three of these shoved in, (on at the bottom, and two at opposing sides) and the rotor does not roll, nor really shift during transport. Onan generators could be built to a closer tolerance as I can't say for certain.
Old 11-21-2017, 02:02:53 PM
Newoldstock Newoldstock is offline
Depending on who made the machine its size and if it is a rewind the tolerance can be larger or smaller.
The 1/16 is quite reasonable.
I used a sheet of a material called DMD, the same stuff they use to make the slot liners ( also off the same roll )
Taper lock between shafts and couplings can be very strong and handle a lot of power.
Large ones are done in a shop to specific tolerances and require heating.
Installed in the field, this usually ends badly...
Old 11-21-2017, 02:05:56 PM
Yup. Some of those are damned hard to get apart as most cannot be heated for expansion.
Old 11-21-2017, 02:18:06 PM
I was just used to hearing spark magnetoes were .010 inch air gap, ( in 1/2" instruments we ran ~.0023 " gap)
In a magnetic circuit an air gap is dominant magnetic drive loss of whole magnetic circuit. So you design gap as small as you can without parts hitting each other as they rotate. Otherwise to have same magnetic flux ( similar to current) you have to compensate by increasing magnetic drive (excitation).
That's why dropping a magneto gap to ~ zero sometimes "fixes" a weak spark, (mag flux might be 10X higher).
How-To, Exciter Rewind (both Stator & Rotor) a31ford Onan Generators 21 02-19-2017 07:26:40 PM
Onan 4.0 BFA Rotor and Stator hog65 Onan Generators 10 02-19-2013 06:20:59 AM
Rust on stator and rotor reggie Onan Generators 1 10-02-2008 01:03:38 PM
PM for rotor/stator...Miller/Onan TomMcnn Onan Generators 0 03-13-2006 10:04:53 PM
Rust proofing rotor/stator Arthur Generators & Electric Motors General Discussion 5 01-23-2005 11:13:05 PM
