Onan 1Kw Gas Generator... K1000
this thread has 41 replies and has been viewed 17040 times
Old 02-16-2013, 06:54:13 PM
Kpack
Default Re: Onan 1Kw gas generator...K1000...
Post your email or pm me with it and I,ll send it to you. I wish I could post the URL off my free cummins account but it doesn't come up. I can load it to my Dropbox and then email it out .
Old 02-16-2013, 07:20:19 PM
Steve Duke
PM sent - Thanks !
Old 02-20-2013, 03:59:54 PM
YellowLister YellowLister is online now
Default Onan 1Kw gas generator...K1000...
so i was overlooking my new to me k1000 and found this sticker on the gen...
here she is doing what she does best... sure is quiet.. those are 500 watt holigens.. i have to keep the choke on just a smudge... couldent get the main jet out.. dident want to risk screwing the carb up..
ID:	158492   Click image for larger version
Old 02-23-2013, 02:14:27 AM
Steve Duke
BIG thanks to Kpack and MrMegoo for the manuals !!!
Old 02-28-2013, 04:58:18 PM
i could really use a breakdown of the carb on this.. ive cleaned the carb and stuck it in my untrasonic cleaner and it still surges unless i put the choke on just a tad.. i need to see if these a o ring missing someplace or maybe the wrong jet... it will idle fine but at opperating speed surges a little.. ive removed the main jet its spotless and cleaned all the passage ways and blown them out a few times its gotten better (having to use less and less choke) each time ive cleaned it.. id like to get and extra needle and seat and gas tank sediment bowl to
email vdub4201@aol.com
thanks in advance!
Old 02-28-2013, 09:00:50 PM
mrmegoo mrmegoo is offline
I emailed you a workshop manual on this unit. Maybe the carb section will help you find the problem.
Mel
The Following User Says Thank You to mrmegoo For This Post:
  #27
Old 02-28-2013, 11:10:21 PM
thank you i got it.. i have to remember these older engines dont like todays gas.. got some good 91 with stabalizer and it cleared up and purrs like it should now
Old 05-31-2013, 11:23:09 AM
grnmich grnmich is offline
I have a KUBOTA 1k identical to this. Mine was built by them. I wonder if they built them for ONAN too. I have a manual for it if you would like it.
Old 06-02-2013, 01:45:55 PM
I found soaking the carbs in 90% rubbing alcohol for a few hours then blowing with air cleans them very well.
Old 07-08-2013, 11:55:17 AM
I uploaded a pic of my Kubota that is identical to that Onan.
Onan Fairbanks Morse v45s-20 generator light plant my first vintage generator DaveinRI Onan Generators 32 06-19-2014 03:19:24 AM
Onan 5.0cck-3cr-13j onan generator, oil in points bubbasz1 Onan Generators 5 03-23-2014 10:32:43 AM
ONAN Help Identify ONAN generator crbearden Onan Generators 1 10-31-2012 01:51:05 AM
old onan generator Jartoy Onan Generators 2 09-27-2005 08:50:17 AM
Onan Generator Warren Madison Onan Generators 0 09-07-2003 11:52:08 PM
