Go Back   SmokStak > SmokStak® Antique Engine Community > Shows and Swap Meets
Shows and Swap Meets Announcements, reviews, photos, movies and discussion about antique engine and tractor shows and swaps.
GAS ENGINE - Slanzi & Lombardini / Alfa Laval #2
this thread has 0 replies and has been viewed 709 times
Old 11-09-2017, 05:33:37 PM
colo colo is offline
Default GAS ENGINE - Slanzi & Lombardini / Alfa Laval #2
Here a Slanzi & Lombardini motor coupled to an Alfa Laval pump
ENGINE
Manufacturer: O.M.S.E.L. Officine Meccaniche Slanzi & Lombardini - Novellara, Reggio Emilia, Italy
Model: S 25
year of construction: early '20s
features: internal combustion engine overhead valve gasoline, magneto ignition, cooling radiator, basement cast iron (later versions are made of aluminum), power 2 / 3 HP, 1000 rpm 1 '. After the dissolution of the company Slanzi and Lombardini, will be produced by Slanzi with the nickname "Balilla".
PUMP
Manufacturer ALFA LAVAL - Milan
features: piston pump with arranged movement alternated/rotary
The Following User Says Thank You to colo For This Post:
alfa laval separator number 5 riverratpeter Farm + Industrial Antiques and Collectibles 0 09-07-2016 05:35:22 AM
Alfa Laval factory separator 1890s brianwalsh Farm + Industrial Antiques and Collectibles 0 04-26-2015 02:09:25 AM
GAS ENGINE SLANZI & LOMBARDINI type "Z" colo Antique Gas Engine Discussion 0 04-05-2015 01:42:08 PM
unidentified Alfa Laval starter?? polymer Unidentified Engines 2 08-18-2009 02:13:22 PM
Alfa Laval pump Yves Farm + Industrial Antiques and Collectibles 3 01-25-2006 07:27:15 AM
