McCormick Deering 10-20 problem
this thread has 5 replies and has been viewed 1940 times
Old 01-12-2009, 01:17:21 AM
rangerfx4man rangerfx4man is offline
Default McCormick Deering 10-20 problem
I have a 1925 McCormick Deering 10-20. We have had it running for alittle over a year now. When we put it up for winter, we encountered a problem. I found that when I was steering the tractor it would make a grinding noise in the transmisson. I also found that if the steering wheel was in the position where the grinding noise is made with the clutch disengaged as soon as i went to engage the clutch the clutch would engage but the tractor would not move and the tractor would stall out if i didn't disengage the clutch. Has anyone had this problem or know what the problem might be?
Old 01-12-2009, 11:01:41 PM
FarmallJeff FarmallJeff is offline
Default Re: McCormick Deering 10-20 problem
Hi I would pull the top cover off and see what's going on in there. I have never had any problems with my 10-20's like that.
Jeff
Old 01-12-2009, 11:11:40 PM
A couple questions:
Does the trans. growl when going straight ahead?
Did you get the tractor to move again once the trans. locked up?
Old 01-12-2009, 11:45:13 PM
We are waiting till the spring when it warms up before we take the transmission cover off. I just thought that i would see if anyone has had this problem before, so I can know what to expect when we do take it apart. It has been a few months since I last ran it, but I believe the tranny did make a slight growling noise while driving straight. But the tractor did move again after it locked up. All I had to do was turn the steering wheel.
Old 01-13-2009, 11:41:24 AM
That's a new one on me...never heard of those particular problems related to steering before. Post what you find when you get it apart.
Old 07-19-2009, 02:30:26 PM
Tyler Martin Tyler Martin is offline
I have a parts tractor if you need some
McCormick Deering T-20 Joe Hugh Antique Farm Tractors 64 11-08-2009 10:45:00 PM
15-30 McCormick Deering Randy L Peterson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 08-23-2009 11:25:12 AM
mccormick deering 1 1/2 hp Roy Bartlett Antique Engine Archives 6 05-10-2004 10:59:34 PM
McCormick Deering M Greg Ledger Antique Engine Archives 2 07-11-2003 08:56:59 AM
6 hp mccormick deering M Richard Rahmier Antique Engine Archives 1 09-09-2001 04:22:37 PM
