25-45 Twin City
this thread has 10 replies and has been viewed 2516 times
Old 08-02-2009, 10:56:36 PM
A Martinson A Martinson is offline
Images: 39
Default 25-45 Twin City
As some of you know, I've been working on making our 25-45 Twin City operational again over this summer. I'm about 95% of the way there now. And it seems like a lot of my spare time not going into working on the tractor goes into researching it, there are a few very interesting things about the TC 25, first of all, they used three different engine style, horizontal crossmotor, vertical crossmotor, and finally vertical inline. The vertical inline engines also came in two different sizes, they started with a 6" bore and 8" stroke. This was later increased to a 6.5" bore. The first three styles had 84" drivers, but everything I've been reading points to the ones with a 6.5" bore having 76" drivers. Also some where built with a single forward speed and some with two. Does anyone know for sure if they built them with two rear wheel sizes?
Old 08-03-2009, 01:58:46 AM
Grant Weir Grant Weir is offline
Default Re: 25-45 Twin City
Hi there Mr. Martinson. I don't know how much this will help as I don't have any measurements for you, but perhaps you will find these pictures I took at the WDM in Saskatoon interesting. I've always called it a 25, but I'm not sure where I heard that. It's kind of a beat-up old girl but she comes out for a run once in a while. Awesome. I just love anything Twin-City. Those guys really made some solid equipment.
Grant Weir
Saskatoon, Sk.
Canada
ID:	59891   Click image for larger version
ID:	59892   Click image for larger version
ID:	59893   Click image for larger version
The Following 11 Users Say Thank You to Grant Weir For This Post:
Old 08-03-2009, 02:00:53 AM
Here's a few more shots of the same tractor...
Grant
ID:	59895   Click image for larger version
ID:	59896   Click image for larger version
ID:	59897   Click image for larger version
The Following 8 Users Say Thank You to Grant Weir For This Post:
Old 08-03-2009, 12:35:11 PM
Mike Harmeling Mike Harmeling is online now
I'm not sure where the pics would be found, but the 25 owned by Sue Dougan in MN seems to have fairly long legs. Don't know the exact specs.
Mike
Old 08-03-2009, 01:02:38 PM
David Parfitt's Avatar
David Parfitt David Parfitt is offline
Mike,
Here is a picture of the one you are referring to.
All the best
David
(Photo: Henry Roskilly)
Name:	Twin City 25 (Sue Dougan).jpg
Old 08-03-2009, 01:51:10 PM
Here's a link that'll take you right to Andrew's site.........this page is loaded with photos of their 25:
http://old-iron.blogspot.com/2008/08...-25-45_20.html
The headless engine is particularly interesting.
When you were digging in the crankcase did you try to get a bore size?......
Old 08-03-2009, 04:57:58 PM
I guess those wheels look about the same after all.
Mike
Old 08-03-2009, 08:55:20 PM
Tanner Remillard's Avatar
Images: 10
A Friend of mine here in Washington has a 25-45 with the vertical inline engine. I think his has the 84" drivers on it, but im not sure what the engine bore is.
Old 08-03-2009, 09:26:43 PM
Eric Best's Avatar
Eric Best Eric Best is offline
I am pretty sure only the first three styles used the 84" wheels. Only the last style had the small drivers and the removable head engine. The rarest in terms of production is the vertical cross motor (25 units or something like that) with the horizontal cross motor being next. I had the last of the three early styles with the jug head engine vertical inline and 84" drivers. Pretty substantial machine to only have been rated a 25-45. Mine was serial number 2772 and had engine number 4140. It was rough.
The Following User Says Thank You to Eric Best For This Post:
Old 08-03-2009, 09:32:58 PM
Images: 39
Thats what I was thinking too, Eric, found some old spec sheets that show a bore 76" drivers and 6.5" bore, no original literature though. Even after making the drivers 8" smaller in diameter, they are still pretty big for a 25HP tractor. Anyone know of a second vertical crossmotor Twin City 25 out there?
Twin City 40 Tom Cwach Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 11-16-2016 03:03:49 PM
Twin City 16-30 Steve Barr Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 23 01-03-2010 05:55:33 PM
Twin City 17-28 ndsunrise Antique Farm Tractors 2 05-10-2009 09:47:18 PM
500 H.P. Twin City Tanner Remillard Steam Stationary Engines, Traction Engines, Steam Boats 2 07-17-2005 12:13:02 PM
Twin City 40-65 Craig A Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 6 12-21-2004 09:19:21 AM
