To trade or not too trade? John Deere LA tractor for JD E 3hp
this thread has 7 replies and has been viewed 2010 times
Old 11-14-2012, 03:10:10 PM
dw1973 dw1973 is offline
Default To trade or not too trade? John Deere LA tractor for JD E 3hp
Hello,
I have an opportunity to trade even up my disassembled 1927 JD E 3hp hit miss for a 1941 JD LA. Not sure if I should take the leap? Opinions? Advice welcome and appreciated.
My hit miss engine needs cleaning/degreasing/paint, honing, muffler, gaskets, decals, and assembly. The mag, igniter and carb have been rebuilt. No breaks/weld repairs anywhere on the engine.
The LA tractor engine turns over when turning the drive shaft - not much compression, carburetor is off the engine currently but the owner has it and said it has been rebuilt, clutch pedal engages, brake pedals move. It obviously needs the correct/missing sheet metal and some home made items removed.
Here are the pics showing both:
Craig here....I give up.... Copy and paste the photobucket link in the first post there >>> http://www.ytmag.com/cgi-bin/viewit.cgi?bd=jd&th=461092
Old 11-14-2012, 06:08:53 PM
Mark K Mark K is offline
Default Re: To trade or not too trade? JD LA tractor for JD E 3hp
Does the LA have the"often missing"serial number tag?
Old 11-14-2012, 06:56:48 PM
I've had 2 JD L tractors.
The one I have now is the first tractor my Dad bought and it's not going anywhere.
There's WAY too much wrong with the tractor you're considering.
Keep your engine.......
Old 11-14-2012, 07:09:12 PM
George Best George Best is offline
I couldn't view the photos, but generally speaking a JD LA tractor is worth more than a 3hp JD.
Of course the missing tractor parts are going to cost more than restoring the 3hp engine will cost.
---------- Post added at 03:09 PM ---------- Previous post was at 03:02 PM ----------
Thanks Craig!
Finally got a link that worked and after seeing the photos I have to agree there is too much wrong with that tractor.
Majority of value is the frame and serial tag.
Old 11-14-2012, 10:37:44 PM
cerwin's Avatar
cerwin cerwin is offline
Keep the engine.
Old 11-14-2012, 11:02:49 PM
Alan Svanes Alan Svanes is offline
I would trade but I like the challenge.
I would see if you could find a hood and the other parts you would need and how much they will cost. Alan
Old 11-17-2012, 06:01:04 PM
Bill Decker's Avatar
Bill Decker Bill Decker is offline
Maybe it's me, but something about the engine on the LA doesn't look right. It looks more like a LUC engine on there. Not that it makes much difference, just saying. Parts for those JD LA's are a bit expensive, been there done that...err, still doing that. I would say it's up to you what you really want, the tractor or the engine. It does look like there is more work to be done to the tractor than the engine.
If you don't teach humor to children when they are small, they will grow up to be adults with no humor at all
Old 11-18-2012, 04:34:08 PM
Ray Cardoza's Avatar
Ray Cardoza Ray Cardoza is online now
if you do go for it heres a guy for pretty much every sheet metal part on them
http://www.vintagetractors.com/jdltin.html
Trade or Keep Ben Cowan Onan Generators 6 08-04-2012 10:11:42 AM
1946 Gibson D tractor - sell or trade / Michigan dw1973 Garden Tractors / Mowers / Scooters 3 12-14-2011 08:38:01 PM
Stover (trade) Bill Antique Engine Archives 0 09-21-2003 06:15:53 PM
TRADE MAG GEAR A.J. TELOWICZ Antique Engine Archives 0 01-29-2003 05:58:30 PM
lucky trade dan cerro---n.j. Antique Engine Archives 0 04-02-2002 09:48:46 PM
