20 HP REID runs again
this thread has 2 replies and has been viewed 2824 times
Old 09-21-2006, 10:21:48 AM
65vette396 65vette396 is offline
Photo 20 HP REID runs again
Thanks to some good buddies of mine and a bunch of help, I have a 20 HP Reid back home from Indiana. This Engine spent its entire life in Oil City, PA. and was purchased 2 years ago still in the original power house and went to Indiana. I recently purchased the engine and now it only thumps for fun from time to time. The Flywheels have what I believe to be as casting dates cast into the counter-weights. The left side is dated 10-17-21 and the right side is dated 10-13-21. This engine is unique in that it is totally original with the exception of a replacement cylinder. All of the serial numbers match with the exception of the cylinder. Crank, bedplate, and both flywheels are stamped 13571 Cylinder is stamped 35344. Am I correct in assuming this engine is a 1921 model and spent 84 years pumping oil in oil city, or are those not casting dates. This engine happens to be equiped with a WICO OC mag and runs great. Engine has tons of compression, all original bearings, all original shims (wood for the mains and paper in the rod), and most original paint. It appears that whatever oil company had the engine had painted it silver, but a good carefull cleaning revealed most the original maroon paint. At any rate I tried to get on Bill Tremels site and had no luck as it seems to be down currently. At any rate any information you experts could provide would be much appreciated. Thanks in advance, Drew
Hopefully the pics come out. Here you go.
Old 09-22-2006, 04:05:28 AM
Ray Cardoza's Avatar
Ray Cardoza Ray Cardoza is offline
Default Re: 20 HP REID runs again
Nice find be careful with the way its resting if it were to tip things could go badly down hill.
Old 09-22-2006, 03:31:22 PM
Thank you sir. It is actually very stable. It doesn't move at all when it is running. I have really enjoyed this engine. The only thing I would like to find are the two original cast pot oilers. They were stolen from the fellow I bought the engine from in Indiana. Thanks again, Drew
The Reid runs Farmer John Oil Field Engines & Related Equipment 11 05-10-2010 03:34:19 PM
!5 HP REID runs again Bob Johnson Oil Field Engines & Related Equipment 11 08-07-2009 09:25:20 PM
20 hp Reid Runs! Chip Watford Oil Field Engines & Related Equipment 6 11-25-2006 07:45:49 PM
12 h.p reid runs again mike jones Oil Field Engines & Related Equipment 0 11-12-2006 10:08:15 AM
8 HP Reid runs again! W.P.Klein Oil Field Engines & Related Equipment 6 02-05-2005 12:35:39 PM
