Fairbanks Morse 118 or 204 questions
this thread has 26 replies and has been viewed 8701 times
Old 09-22-2010, 11:40:46 AM
Walt Roys Walt Roys is offline
In Memory OF
Default Re: Fairbanks Morse 118 or 204 questions
David,
I sent an e-mail to you with more Info on contacting me.If you get it contact me.
Walt
The Following User Says Thank You to Walt Roys For This Post:
Old 09-24-2010, 12:35:53 AM
In Memory OF
Here are a couple of pics of the 118 I did last winter.
Walt
ID:	88304   Click image for larger version
ID:	88305   Click image for larger version
ID:	88306   Click image for larger version
Old 09-24-2010, 07:39:46 AM
Reed Engine's Avatar
Nice work Walt, if you ever need a job....
The Following User Says Thank You to Reed Engine For This Post:
  #24
Old 10-17-2010, 10:24:49 PM
shortyshvac shortyshvac is offline
Hi Guys, I am new to this forum as well as new to the hobby. I have always had an interest in these old motors and never had a chance to dive in. I was at a tractor show last week and found what I believe to be a ZC118. The tags lists 6 and 7 HP. It seemed mostly complete except for the plug wire and it was mounted on a cart. The 100.00 price tag seemed great so I bought it. When I got it home I noticed the head had been welded as well as the bottom of the water jacket under the cylinder. The weld job seems solid and the motor has compression. I checked the mag out and the coil is grounded. If you guys dont mind helping a rookie I will probably ask for information on a regular basis as I get into this project. I tried to attach a picture. I hope it works.
Old 10-17-2010, 10:35:08 PM
This is the picture I was trying to uplaod.
Old 10-18-2010, 10:38:54 PM
$100.00? I'd say you did good.
Old 11-28-2010, 12:00:25 PM
Scott L Scott L is offline
Here is a picture of one I got at the Salvage yard for $20. Probably one of the cheapest engines I've bought. It was missing the head. Before and after pictures.
ID:	93736   Click image for larger version
Fairbanks Morse ZC-503 and ZC-346 Questions Christian Berlin Hit & Miss Gas Engine Discussion 14 10-26-2009 11:58:50 PM
Fairbanks Morse 3 hp Z questions? Zira Hit & Miss Gas Engine Discussion 21 02-17-2009 10:46:24 PM
Fairbanks Morse 3 hp Z Questions Doug Kimball Hit & Miss Gas Engine Discussion 1 01-22-2009 10:41:33 AM
Questions on Fairbanks Morse Shine Stringer Hit & Miss Gas Engine Discussion 10 10-03-2007 02:38:16 AM
Fairbanks Morse 3HP ZC Questions Alan James Hit & Miss Gas Engine Discussion 0 05-29-2007 03:55:28 AM
