Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Solar and Wind Power for Home, Farm & Industry
Solar and Wind Power for Home, Farm & Industry Windmills, solar panels and inverters for standby power.
Hi-Power Wind Turbine, Delco Farm Lights Windy Cousin
this thread has 3 replies and has been viewed 4723 times
Old 03-07-2013, 03:16:47 PM
westtexas86004 westtexas86004 is offline
Question Hi-Power Wind Turbine, Delco Farm Lights Windy Cousin
Hello,
My name is David and I recently acquired a Hi-Power Wind Turbine. This wind turbine was made by Delco Farm Light for part of 1938 so there are not many examples to be found.
This turbine was originally wired for 1KW at 32vdc, however the windings were fried in the example that I purchased and I had the fields and armature rewound.
I had the generator rewound for 48vdc @ 1KW and I am now in the process of rebuilding the brush assembly. This is where I am hoping some of the Delco Farm Light owners can assist me.
This generator uses an odd brush arrangement. Normally brushes are positioned at 180* to each other, but in this instance the brushes are set at 90* to each other. Is this normal for Delco Generators from that time period or is this peculiar to the wind turbine generator only?
I would also like to know if anyone knows of a source for brushes and brush spring clips for this generator?
Thanks, David
"As an interesting highlight, Delco-Light developed a highly credible 1,000-watt wind charger named “Hi-Power” briefly in 1938."
http://www.windcharger.org/Wind_Char..._Electric.html
Ad here; http://www.windcharger.org/Wind_Char...l_of_Fame.html
The Following 2 Users Say Thank You to westtexas86004 For This Post:
Old 03-07-2013, 08:43:34 PM
Default Re: Hi-Power Wind Turbine, Delco Farm Lights Windy Cousin
I don't know about Delco generators but, if you have a four pole, which you have from the photograph; then having two brushes 180° electrical apart - 90° mechanical- indicates the winding is a wave winding not a lap winding.
In a lap winding the connection from each commutator segment to the winding goes to the armature slots completes the number of turns and comes back to the adjacent segment. In a wave winding the start and finish of the winding are opposite on the commutator. Only two brushes are needed on a wave winding, more can be fitted if current density is a problem.
As for the brush gear there are guidelines on brush pressure per unit area related to the brush grade. However, the pressure is usually in the 18 - 22 kN/m˛ range for carbon brushes. Metallic brushes will be different.
The Following User Says Thank You to Radiomike For This Post:
Old 03-26-2013, 11:45:39 AM
Originally Posted by Radiomike View Post
. . . having two brushes 180° electrical apart - 90° mechanical- indicates the winding is a wave winding . . . In a wave winding the start and finish of the winding are opposite on the commutator. Only two brushes are needed on a wave winding, more can be fitted if current density is a problem.
Hi Mike,
Very good information. Much obliged.
Dave
Old 03-26-2013, 01:25:27 PM
Power Power is offline
Any large electric motor repair shop should be able to provide appropriate springs and carbon brushes with similar characteristics. Bring old ones with you.
I often have shop match up brushes/springs for me
Delco Light Power Batteries for Farm Electrification Service SDP Delco and other Low Voltage DC Light Plants 16 06-06-2012 01:55:38 PM
Alternator for Low Wind Speed Wind Turbine Needed mechamz Generators & Electric Motors General Discussion 3 05-22-2008 11:20:05 AM
Alternator for Low Wind Speed Wind Turbine. mechamz Generators & Electric Motors General Discussion 3 05-15-2008 08:16:49 PM
