Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Generac Generators (SEARS, etc.)
Generac Generators (SEARS, etc.) Restoring, maintaining and operating Generac generators.
17kw generac starts and shuts down after 2 sec
this thread has 11 replies and has been viewed 8315 times
Old 11-16-2012, 10:34:14 PM
wstang254 wstang254 is offline
Default 17kw generac starts and shuts down after 2 sec
hi hopefully someone on here can help , i had a customers 17 kw ran for 5 days straight and on the 6th day shut down, checked the gas pressure its good, the unit cranks on manual starts up and shuts down after 2 seconds , red light is on , on the side , can't seem to find someone with same issue on the net .
unit has oil
Thanks to you guys i was able to fix my older dayton which had governor issue , the weights were stuck in the motor and got them to free up , thanks
Old 11-17-2012, 12:01:16 AM
DriverR DriverR is offline
Default Re: 17kw generac starts and shuts down after 2 sec
You have come to the right place. The guys will ask for a model #.
I thought we were on the Onan forum, sorry.
Old 11-17-2012, 12:10:41 AM
unit is 10 months old , bought at apelectric dot com , with 200 se switch , i would have to stop by owners house to get model or serial.
Old 11-17-2012, 01:05:21 AM
The unit should be covered under warranty, if you want to fix yourself thats fine. It will shut down if certain parameters are not met i.e. oil pressure or not generating. Have you done any type of checking to confirm essential operating conditions. Does it generate within the two seconds prior to shutdown.
Old 11-17-2012, 09:15:41 AM
Joe Romas Joe Romas is offline
Like driverR says
You could try bypassing the oil pressure switch to rule out low pressure or a bad switch
BUT if there's no or low oil pressure things could get nasty fast
Old 11-18-2012, 03:23:22 AM
Smile Re: 17kw generac starts and shuts down after 2 sec
thanks alot for the help, unit is covered under warranty , but i wanted to know in time of crisis, you know how hard it is to get a tech out during power outtage, if i get a chance will try to get over to the unit to check a few more of the things everyone suggested.It makes me frustrated and mad when you can't solve something lol. i went to motorcycle mechanic school years ago and after fixing my own generator i find them interesting , like a complecated puzzle , can never learn too much , plus if you find it is something minor during a black out and you can fix it makes one very happy customer
Old 11-19-2012, 11:27:37 PM
byrone byrone is offline
If it shuts down after 4 seconds then it is likely the low oil pressure switch. If it shuts down after 2 seconds, then likely it is the rpm sensor on the flywheel. It can go bad or go out of adjustment. Check the sensor output while running , even if only 2 secs, you should get 0.4-0.6 v AC and the sensor should have 1000 ohms +- 10 % resistance. You can adjust the sensor to flywheel gap down to "one half turn" in Generac speak if the voltage output is not there. Also listen if the starter disengages or not after the 2 sec runtime. I it does disengage like normal, then you likely have an engine problem. But don't know your exact model, so these are only generic Generac troubleshooting guidelines I have learned.
Old 11-20-2012, 11:29:44 AM
Bassplayer1985 Bassplayer1985 is offline
Wstang,
Did you remove the oil pressure sensor temporarily? Is the customer in Shelton? Shelton is super close, right down Route 8 for me.
Old 11-20-2012, 08:29:30 PM
Most modern generacs won't start at all unless they see a zero voltage from the oil pressure switch, verifying that it is there, it's a fail safe. So if you remove the oil press switch wire, you should get a no start at all. Unless the logic changed on this model. But worth a try.
Old 11-21-2012, 09:34:00 AM
Billy J Shafer's Avatar
If it is under warranty. Don't touch it. Generac finds out and you can kiss warranty goodby. I have seen it happen many times.
Old 11-21-2012, 10:26:23 AM
Billy is right Wstang, see if the warranty will kick in, it sounds like a simple issue to correct, and why spend money when warranty will cover it.
Old 11-21-2012, 11:50:30 AM
Did anyone check the oil level? I sure wouldn't let generac see it unless it was full of oil! and after several days runtime, maybe it ran out....more common then you might think!
Generac starts but won't stay running RoyW Generac Generators (SEARS, etc.) 13 05-07-2019 07:32:04 AM
Generac 17kw starts n shuts down wstang254 Generac Generators (SEARS, etc.) 13 11-17-2012 04:00:59 AM
Onan 6.5MCCK-3CR/1H Starts runs for 45 seconds and shuts off truk911 Onan Generators 4 10-16-2011 03:47:58 PM
Generac xp 6247-8 starts but will not stay running Kevin Henshaw Generac Generators (SEARS, etc.) 3 05-19-2010 05:31:38 PM
Onan generator/ starts then shuts down Styners4x4 Onan Generators 3 06-22-2009 06:04:42 PM
