Oil Field Engines
Hot tube Question
this thread has 6 replies and has been viewed 1863 times
Old 01-11-2013, 12:56:35 PM
Adam Hartz Adam Hartz is offline
Default Hot tube Question
I have a Myrick Eclipse and there is an insulation material in the hot tube, might be asbestos. It is getting old and falling apart. What can or should I use to replace it?? Where can I find it?
Any help would be appreciated.
Adam
Old 01-11-2013, 02:25:59 PM
Forrest A's Avatar
Default Re: Hot tube Question
Amorphous silica fabric. ASFs are used in muffler packing and also in furnace applications. It is used in high temp applications. It, like anything else has its pros and cons. Make sure you check the cons before using any material so there are no surprises. (Info found by googling "good replacement for asbestos")
The Following User Says Thank You to Forrest A For This Post:
Old 01-11-2013, 06:53:30 PM
Mike G Mike G is offline
Adam,
I use FiberFrax paper. We use it here at work for the construction of aluminum melters. 1/16 in thick material works great!
A quick Google source revealed this by the foot source:
http://www.aircraftspruce.com/catalo.../fiberfrax.php
Mike
The Following User Says Thank You to Mike G For This Post:
Old 01-12-2013, 02:50:32 PM
neilert neilert is offline
That is where I ordered fiberfrax (aircraft spruce), and have always had good luck with that company. Neil
The Following User Says Thank You to neilert For This Post:
Old 01-14-2013, 08:08:41 AM
Do you guys use just one thickness of the fiber?
Thanks for the help.
Adam
Old 01-14-2013, 08:58:11 AM
Joel Sanderson Joel Sanderson is offline
I'm using Kaowool in my chimney, Adam. I use it in my forges too. I got mine from a friend, but I just did a search for it, and it seems to be about everywhere, including Ebay. You can sort of peel it to make it thinner if you need to. I peeled mine down to about a quarter inch or so, then rolled it against the walls of the chimney with a dowel to lay the fibers down.
Joel
The Following User Says Thank You to Joel Sanderson For This Post:
Old 01-14-2013, 09:11:02 PM
Adam, I am using one layer of the 1/8" thickness material, but the 1/16" should work fine. The fiberfrax fibers are packed flat, sort of like building felt.
kohler light plant 1a21 rocker oil tube question YellowLister Kohler Generators 3 12-17-2012 05:11:01 PM
Bessemer style hot tube question Ray Ethridge Oil Field Engines & Related Equipment 12 10-11-2012 09:01:03 PM
F/M 2hp T hot tube Engine Whisperer Hit & Miss Gas Engine Discussion 2 02-21-2009 04:19:25 PM
Onan 15 JC Breather tube question Don Smith Onan Generators 3 06-06-2008 01:03:14 PM
Hot Tube Set up Jerame A Antique Engine Archives 3 08-29-2002 12:09:39 PM
