Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Solar and Wind Power for Home, Farm & Industry
Solar and Wind Power for Home, Farm & Industry Windmills, solar panels and inverters for standby power.
Wincharger 6volt for 12volt lights?
this thread has 1 replies and has been viewed 3145 times
Old 05-01-2013, 02:57:12 PM
Cruachan Cruachan is offline
Lightbulb Wincharger 6volt for 12volt lights?
I have acquired an original Wincharger Zenith 6v generator for the garden that I'd like to use to power a set of garden lights.
Now the lights I've built myself... they are illuminated by 10-30 VDC LED tower bulbs (automotive type).
Now, i'd like to have the lights illuminated whether the turbine is turning or not, so that means a set of batteries to power directly and to use the turbine for charging.
Can anyone recommend a system set-up? I realise that since the generator provides less voltage than the required 12 volts for the bulbs, I may need to step-up using a transformer and perhaps switch between two individual batteries (charge/supply).
Any thoughts on protection? Recommended switching/control?
Thanks,
Jock
Old 05-01-2013, 10:23:11 PM
Default Re: Wincharger 6volt for 12volt lights?
You may find this link informative and useful
http://www.fieldlines.com/index.php?topic=144033.0
If it is a standard automotive type dynamo then there are lots of sites detailing 12 Volt conversions. Is the generator a two or three brush unit?
This site may have manuals
http://www.cybergus.com/wincharger/s...1man/index.htm
6v wincharger and radio ad question Barnbikes Solar and Wind Power for Home, Farm & Industry 6 03-05-2014 06:15:02 PM
6 Volt Wincharger Models 611 & 37 Info please Brian Lynch Solar and Wind Power for Home, Farm & Industry 5 02-10-2014 04:58:30 PM
Zenith Wincharger 6 V info Gary Bahre Generators & Electric Motors General Discussion 1 02-12-2011 05:18:35 PM
Low tension coil and 12volt battery? Gene Fisher Hit & Miss Gas Engine Discussion 9 04-13-2009 05:25:56 PM
6Volt light bulbs seth Generators & Electric Motors General Discussion 2 08-14-2002 01:40:19 AM
